installing 1 new pushrod
Old Oct 1, 2020 | 02:17 PM
King Sol's Avatar
King Sol
I have a 460 cu in big block, bored out to 509 cu in.
After noticing valve train noise, I removed the valve cover and noticed that the rocker was very loose on intake cylinder 1.
The head of the pushrod was slightly bent. I am replacing it with a new push rod.
Not wanting to take off the intake manifold, I just want to replace the one pushrod in its place and then re-adjust with the right procedure the roller rocker for that pushrod.
Is the following the right procedure?
1. After dropping in the new rod and reinstalling the rocker I hand tighten the rocker nut until no valve lash.
2. Turn the engine until the exhaust valve on cylinder 1 starts to move slightly.
3. Re-tighten the rocker adjusting nut by hand until no valve lash.
4. Give the adjusting nut 1 complete turn and then tighten the locking hex nut inside the rocker adjusting nut.
5. Verify all the other rocker nuts are tight.
Old Oct 4, 2020 | 07:15 AM
headloct's Avatar
headloct
Make sure you don't accidentally pull the lifter out of it's bore when removing pushrod. Any idea what caused the pushrod to bend?
Old Oct 4, 2020 | 01:02 PM
King Sol's Avatar
King Sol
The rocker got loose to the point of having a play of 1/8 of an inch on top of the pushrod and on top of the valve stem. The adjusting nut and the lock nut of the rocker both got loose.
Since my 1st post I have replaced the pushrod and I readjusted all of the 16 rockers for valve lash using a method I saw online but I botched it up and then the truck wouldn't start and it seemed like the timing was off, but it turned out it wasn't the timing. Since then my engine builder described another method that I will use to adjust valve lash and the valves. It's the EOIC method (exhaust, opening, intake, closing).
Keeping my fingers crossed.
Old Oct 4, 2020 | 04:44 PM
mark a.'s Avatar
mark a.
Is this a solid cam or hydro ?
Old Oct 4, 2020 | 07:17 PM
King Sol's Avatar
King Sol
It is a hydro.
Old Oct 4, 2020 | 11:37 PM
mark a.'s Avatar
mark a.
Originally Posted by King Sol
It is a hydro.
A hydro cam does not have lash it has preload, two different things.
Montync
16
Apr 3, 2016 01:55 PM
aricanderson
Jan 14, 2011 10:27 PM
CatFlip
Jul 31, 2006 07:58 AM
TigerDan
May 14, 2004 11:22 AM
1200bandit
Oct 18, 2003 09:41 PM
