October 2020 All topic thread
Old Oct 1, 2020 | 12:03 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Hello Nor Cal.
Welcome to the Spooky month of October. According to the news last night, the Creek fire should be 100% contained by the end of the month. I pray by then some of the other fires will also be 100% contained as well.
Jim
Old Oct 1, 2020 | 12:40 PM
GlueGuy's Avatar
GlueGuy
Smoke here is off the charts this morning. it was OK early, around 7AM, then it turned awful by 8AM. The rapid change was somewhat startling.
Old Oct 1, 2020 | 01:46 PM
Nighteyez's Avatar
Nighteyez
Happy thirsty Thursday Nor Cal. Maybe we will get lucky this month and get some much needed rain.
Jim
Old Oct 2, 2020 | 01:24 PM
Nighteyez's Avatar
Nighteyez
Happy Friday Nor Cal.
Jim
Old Oct 3, 2020 | 10:54 AM
Tim Young's Avatar
Tim Young
Good morning Nor Cal.
I missed last month. Sorry to hear of all of the fires down there. We had a couple of bad ones last month here also. My cousin in Southern Oregon lost his house and all his belongings to a fire last month.
I hope all is well with you guys.
Old Oct 3, 2020 | 01:11 PM
Nighteyez's Avatar
Nighteyez
That is terrible. I can't imagine losing everything I own.
Jim
Old Oct 4, 2020 | 02:20 PM
Nighteyez's Avatar
Nighteyez
Happy Sunday Nor Cal. Hope everyone is having a blessed day.
Jim
Old Oct 5, 2020 | 11:44 AM
GlueGuy's Avatar
GlueGuy
Really digging the suddenly clean air. Now if it would just cool off a bit.
Rumor of possible rain in N. California possibly as early as Friday morning.
Old Oct 5, 2020 | 09:54 PM
Nighteyez's Avatar
Nighteyez
It is getting cooler here. Using the AC less and less, which is a good thing because I can't afford another PG&E bill like this last one.
Jim
Old Oct 6, 2020 | 09:32 PM
Modoc's Avatar
Modoc
We are in for a roller coaster for the next several days. 70’s on Saturday and back to the 90’s by Wednesday.
here is to hoping that we get some decent moisture from the front coming through.
Old Oct 7, 2020 | 11:21 AM
Nighteyez's Avatar
Nighteyez
Much cooler today. No AC use in site. Looks like it will be warming up again in a few days though.
Jim
Old Oct 8, 2020 | 02:34 PM
Nighteyez's Avatar
Nighteyez
Happy Thursday Nor Cal. Looks like I might be buying a second gen (89-92) Ranger in the next month or two. Might have to wait for the second stimulus, but I am told I can get it for $500 if the owner doesn't put a gas tank in it. Higher if he buys one and installs it. Some A hole put a hole in the current one. It needs a battery and a tune up also as it has been sitting for at least 4 years (when I moved in) but he says he has a brand new battery sitting in his apartment for it. It has faded paint and the clear coat on the hood is badly peeled, but no major dents or rust. It does need the inside door latches though. It is the 2.3 liter four, and has an auto trans, which is perfect for me with my bad knee I can't drive a manual trans vehicle anymore. It has a contractor rack in the bed with a bed liner, and after market wheels. I'll get some pics of it next time I go out in the parking lot.
Jim
Old Oct 8, 2020 | 04:51 PM
Nighteyez's Avatar
Nighteyez
Hello,
Okay, so I went out today to get some pics.
Not bad for $500. It looks like it will need a front end alignment as well as a tune up, and the replacement gas tank. I plan on changing the oil and all filters, and maybe even the serpentine belt and all hoses as well. Since he already has a new battery for it, the only big expense will be the gas tank. I am also hoping he has the center caps for the wheels too.
Jim
Old Oct 9, 2020 | 01:20 AM
Fifty150's Avatar
Fifty150
it is misty in Chinatown
Old Oct 9, 2020 | 01:35 AM
Fifty150's Avatar
Fifty150
Not bad for $500
Jim, think about the tires, brakes. Cooling system, automatic transmission..... You could be spending $500, to buy $5,000 worth of deferred maintenance. Based on my previous experience, with a truck that age, the transmission and differential will require service. Suspension will set you back at least a set of shocks. Thermostat, fan clutch, water pump, belt, and sometimes even pulleys are needed. AC needs recharge. All sorts of seals and gaskets are worn. PCV & EGR valves will become a problem. O2 sensors are fouled. Engine may need a new timing belt. 8 track player is stuck and you are stuck with Lionel Ritchie. Upholstery smells like a dirty prostitute.
Don't let me scare you. Enjoy the truck. $500. I know hookers that charge more for a ride.
