High temps resolution!
Old Sep 30, 2020 | 07:52 AM
arno's Avatar
arno
"UPDATE"
Had my 17 in again to Ford for the running hot issues. Several have had similar problems so I wanted to post the resolution. After telling me 227-232 unloaded down the highway was within spec and I have no issues, I persisted and they found the thermostat was bad! Thats all it was and It caused the fans to run high, the numbers to pop up above the factory gauge, constant temps in the 230s not towing. While yes these trucks do run "hotter" they shouldn't be that hot. I now have average temps at 210-213 on the highway, unloaded, and about 208 in town. They replaced the thermostat with another 195, as thats whats in the 17, and it has only hit 222 with a trailer and about 3000lbs. It immediately dropped back down when I crested the top of the hill.
Several others have experienced similar problems and might try the thermostat replacement. Cheap fix, all things considered lol.
Old Sep 30, 2020 | 11:43 AM
Bluegrass 7's Avatar
Bluegrass 7
I thought I offered some operational temps from my 18 and 02 but what temp are you stating?
The engine cooling system or the trans temps?
On my 18, I can see the Trans on the small dash panel display.
I need to use a Scanner to see the actual 'engine cooling' system temperature aside from the dash gauge that is only a rough indicator.
Just wanting to understand for the future.
Thanks.
Old Sep 30, 2020 | 12:20 PM
arno's Avatar
arno
When your truck gets over 225 (coolant), numbers pop up over the sweep gauge. Newer models anyway. My numbers started showing up a few months ago. I also plug an old tuner in so I could monitor temps live so to speak.
The engine cooling system or the trans tv temps?
Thanks.
Old Oct 2, 2020 | 07:49 AM
Tom's Avatar
Tom
Misinformation is frustrating, especially when it comes from a dealer. Nothing is supposed to run "hotter"… You have the exact same temperature thermostat that my 16-year-old Expedition does.
Old Oct 2, 2020 | 07:51 AM
arno's Avatar
arno
Ok. Just posting to do my part and return with a resolution, once I had it.
My 18 has a 180
Old Oct 2, 2020 | 08:32 AM
Tom's Avatar
Tom
Which engine does your 2018 have?
Old Oct 2, 2020 | 08:38 AM
arno's Avatar
arno
Hahaha that guy. Have a great day.
Old Oct 2, 2020 | 10:22 AM
Tom's Avatar
Tom
That was an honest question. I try and keep up with things, but it's not easy doing that with a hand disability. You piqued my interest, so I looked up what I thought was the most common engine, but my hands weren't up for digging through the rest of them.
Old Oct 2, 2020 | 04:36 PM
Stealth13777's Avatar
Stealth13777
Thanks for posting a resolution. To the poster asking about the digital temps, that will only happen with the digital dashboard - lariat and above
Old Oct 2, 2020 | 06:38 PM
arno's Avatar
arno
Very true, just hope you don’t have to worry about the numbers showing up. If they do, Ford will pretend like they don’t know why they do that lol.
arno
2015 - 2020 F150
Sep 28, 2020 07:27 PM
arno
2015 - 2020 F150
26
Sep 25, 2020 01:38 PM
ACEN
Jan 8, 2013 12:27 PM
Bowstring
Jan 5, 2008 03:13 PM
nudgey
May 24, 2004 06:56 AM
