203 Thermostrat
Old Jan 5, 2008 | 09:37 AM
Bowstring's Avatar
Bowstring
203 Thermostrat
What was the reason Ford went to the 195 degrees if the 7.3 originally came out with the 203 or did it?
Old Jan 5, 2008 | 09:45 AM
ron's power stroke's Avatar
ron's power stroke
quoted from diesel site.. http://www.dieselsite.com/index.asp?...ROD&ProdID=186
Until 1996, all 7.3L Powerstrokes that were manufactured used an International water pump and an International short stem 203<SUP>o</SUP> thermostat . In 1996, Ford changed to a lower degree 195<SUP>o</SUP> thermstostat. They changed water pump designs at this time as well. The new pumps required the new long stem 195<SUP>o</SUP> thermostat in place of the short stem to properly seat the bypass disk. All 1996-2003 Ford PSDs now come equipped with a long stem 195<SUP>o</SUP> thermostat. Recently the factory replacement thermostat available at the parts counter changed to 192<SUP>o</SUP>.
*If you have a pre-1996 vehicle, call us for the proper thermostat for your truck.
WHY IS 203<SUP>o </SUP>BETTER THAN 195<SUP>o</SUP>?
Diesels run most efficiently at approximately 200<SUP>o</SUP> or above. A factory equipped 192<SUP>o</SUP>/195<SUP>o </SUP>thermostat will maintain an operating temperature at approximately 165<SUP>o</SUP>-170<SUP>o</SUP>. The Powerstroke has such an efficient cooling system, that this low flow when the thermostat is slightly open is normally enough to keep the engine cool. The downfall to this is that the engine -- when our trucks are not under load --never begins to reach its optimal operating temperature. Our 203<SUP>o</SUP> thermostat maintains a minimum operating temperature of 190<SUP>o</SUP>. This brings the operating temps up from as low as 170<SUP>o</SUP> to as high as 203<SUP>o </SUP>depending on the operating conditions of the truck. This is closer to the operating temperature range that is preferable in our trucks for optimal efficiency.
When our trucks are under load and are producing higher combustion temperatures the 203<SUP>o</SUP> will allow the engine to run even closer to its optimal operating temperature. If the truck is under load and reaches the 203<SUP>o</SUP> setting, the thermostat is then fully open. This means you are at the maximum coolant temperature that the truck will reach. Your maximum temperatures are only a few degrees higher than in stock configuration, but these are degrees that you want for better performance. The best benefits come when the same truck is under a light load and would have a hard time reaching this optimal temperature. As stated above, you will never reach this optimum temperature with the stock 195<SUP>o</SUP> thermostat. The end result of installing the 203<SUP>o</SUP> thermostat should be slightly better fuel economy, less smoke, and maybe a few extra "ponies" to go along with it.
WHY A LONG STEM AND NOT A SHORT STEM?
Although International still uses a 203<SUP>o</SUP> thermostat in some applications and that thermostat is available at most auto parts stores, it is the wrong part for the 1996 - 2003 Powerstroke. DO NOT USE THIS! It has a shorter shaft and will not shut off the internal pump bypass. This will cause inaccurate coolant flow direction through the engine. This IH version thermostat mentioned is available by calling us.
The thermostat in the Powerstroke not only controls operating temperatures, but properly directs the flow of coolant through the engine. As the thermostat opens, it proportionally closes the bypass. With the thermostat fully open, the bypass is mostly closed, and vice versa. With the International (Pre-96 Ford) thermostat, this cannot be controlled properly because of the shorter bypass stem. The shorter stem of the IH(pre-96 Ford) thermostat allows the thermostat to be fully open while the bypass is fully open. This means the coolant can travel in any direction available -- whatever direction it chooses. It can either travel through the radiator or simply make the shorter, less restrictive path back through the front of the engine. This will cause uncontrolled overheating in the back cylinders of the block, with absolutely no signs of danger showing on the water temperature gauge in the cab. It is possible that the back of the engine can have no coolant flow at all yet the thermometer in the outlet of the water pump shows all to be normal. Multiple things can happen at this point. Cylinders can seize, freeze plugs can fall out and other normal symptoms of an overheating engine may occur. Worst case is a blown motor and it won't be covered under warranty.
We know the warranty departments and engineers at Ford have verified engine loss due to the short stem thermostats in previous cases where people were sticking into their trucks to increase their operating temperatures. As soon as they see the short shaft thermostat -it's your problem. Our 203<SUP>o</SUP> thermostat will not encounter these problems! It's designed to work as the OEM unit did WITH the long stem for bypass protection.
Old Jan 5, 2008 | 10:02 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Awesome post there Ron, i added to your reputation.
Old Jan 5, 2008 | 10:06 AM
ron's power stroke
Kris...
Old Jan 5, 2008 | 12:34 PM
powerstroke1869's Avatar
powerstroke1869
how hard is it to replace the thermostat
Old Jan 5, 2008 | 12:50 PM
ron's power stroke
the hardest part is not breaking the bolts...spray them good for a day or two so it sokes in good.. also very helpfull in the future stat change and not haveing leaks..is to get the billet aluminum housing...
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=188
Old Jan 5, 2008 | 02:18 PM
WMRiceman's Avatar
WMRiceman
concur with the breaking of the three little 6mm bolts. That is how I ended up changing my first water pump out. One broke off at removal. I still can't bring myself to torque them to more than 10 ft lbs (I know the book says 15 to 20 ft lbs). I just replaced the t-stat and housing with the billet aluminum one. I torqued the bolts to 10 and no leaks. Thoses 6 mm bolts are rated at 6 to 9 ft lbs according to the front of the haynes manual. I use anti-seize. I just can't see taking those little bolts to 20 ft lbs.
Old Jan 5, 2008 | 03:08 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
I changed mine in no time, don't forget the new billet housing.
Old Jan 5, 2008 | 03:13 PM
jhand124's Avatar
jhand124
I just orded the stat and housing last night, I'm looking forward to the increased temps.
