Sponsored by: Real Truck
Oh Boy
Old Sep 26, 2020 | 08:20 PM
ScoggDog's Avatar
ScoggDog
Oh Boy
2016 F250 - 80K miles - made a big noise today like a backfire as I got on it pulling out, and immediately felt like it was missing or skipping. Was only a few minutes from home - limped back to the house. Engine light is now on. The kicker - found a 2 1/2" x 1" steel ring in my driveway - like something fell off. Starts fine - sounds fine at idle - but has that stutter feeling. Nothing leaking. No clue. Maybe the piece of steel is just trash ?
Any ideas ?
Old Sep 26, 2020 | 09:15 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Any ideas ?
What engine is in your truck?
Old Sep 26, 2020 | 11:24 PM
edjunior's Avatar
edjunior
If you got a check engine light, you got a code. Get the code read. See what it says. Then come back and let us know.
Old Sep 27, 2020 | 07:05 AM
senix's Avatar
senix
also maybe a picture of what you found.
Old Sep 27, 2020 | 11:53 AM
ScoggDog's Avatar
ScoggDog
Thanks peeps. Took it out this morning - definitely still "missing" or "skipping". If it was a gasser, I'd look at plugs. Might be the dreaded injector. I'll take it in Monday. I've got a powertrain warrantee - we'll see what happens. I do need to get my own code reader.
The "part" I found is just a carbon steel ring, exactly 2.5" round by 1" thick - thinner than schedule 40 pipe. I'm guessing it's just trash that ended up in the driveway. It confused me though, because it did have some type of thin film on it. But nothing is leaking out from under the truck - if it had ejected a piece that big, I should be able to see something. Compression is still good as far as I can tell - nothing coming out when I remove the oil cap. Idles just fine.
I think it's an injector. When it "misses" - I don't hear the engine winding - so I don't think it's a transmission issue. And as little as I drove it, it did get a bit better. Again - that points to an injector, right ?
Thanks again for your replies.
Old Sep 27, 2020 | 11:55 AM
ScoggDog's Avatar
ScoggDog
And sorry - it's a 6.7 Powerstroke. First diesel I've ever owned - and bought it used. So the stress factor is up a bit.
Old Sep 28, 2020 | 06:22 PM
ScoggDog's Avatar
ScoggDog
Well - thanks again for everybody that replied. Truck is fine - it blew off the cold side intake to the turbo - then the damn thing went into limp mode and then started re-mapping the transmission.
Long story short - I'm going to have to get a code reader. And then I'm going to have to learn about these modern diesels. And start doing some of these things myself, and re-setting my own fault codes. Still like the truck - I just need to get up to speed on all this stuff.
And again - thanks for all the offers of help. Appreciate it.
StephanieKY
Aug 14, 2020 08:47 PM
drewinator
Nov 8, 2014 07:10 AM
61 uni
22
Dec 1, 2009 03:40 PM
F250wrx
Jun 16, 2007 08:10 PM
JMorton
Feb 27, 2004 11:47 AM
