TV cable for AOD
Old Sep 25, 2020 | 02:06 PM
Javier Aguilar's Avatar
Javier Aguilar
TV cable for AOD
I have a 1988 F-150 with a 302 and an AOD transmission which I am looking for the lockdown cable for. Any help is appreciated
Old Sep 25, 2020 | 03:00 PM
85e150's Avatar
85e150
Welcome to FTE
The cable or linkage from the carb to an AOD is not a kickdown cable or linkage. It is a Throttle Valve cable, and must be adjusted properly or you can ruin your transmission in just a few miles.
This forum deals with transmissions. This has come up before and I will find you some links shortly.
For an OEM part, it's the junkyard. Or try this:
https://www.lokar.com/assets/instruc...D-Kickdown.pdf
Old Sep 25, 2020 | 03:22 PM
85e150's Avatar
85e150
https://www.ford-trucks.com/forums/1...p-the-aod.html
Since yours is OEM, this is a bit OT but explains some stuff about the AOD when transplanted.
https://static.summitracing.com/glob...tci-431000.pdf
There are YouTube videos etc, but the Lokar link above ought to get you there.
351Cleveland C4
Feb 25, 2014 12:31 PM
reed1951
Jan 2, 2014 05:50 PM
BIGskinny
Aug 21, 2013 07:57 AM
jk080
Sep 14, 2009 04:31 PM
71mustang
Mar 30, 2002 12:51 PM
