AOD kick down bracket for carb
Old Aug 20, 2013 | 02:03 PM
BIGskinny's Avatar
BIGskinny
does any one know where i may be able to find a kick down cable bracket for a carb?
Old Aug 20, 2013 | 03:43 PM
rla2005's Avatar
rla2005
Lokar makes several. Here is one: http://www.summitracing.com/parts/lok-kd-2aodu
Old Aug 21, 2013 | 07:44 AM
Conanski's Avatar
Conanski
The AOD doesn't use a kickdown cable it's a throttle valve(TV) cable that varies line pressure in the trasnmission in sync with throttle position, so it must be connected and set with the proper preload or transmission damage is likely. Once you get the cable have a look at this video.
Old Aug 21, 2013 | 07:57 AM
rla2005's Avatar
rla2005
Paul is correct, but Lokar and others wrongly refer to it as a kickdown cable. The cable assembly I found is listed for controlling an AOD with a carb'ed engine. Many of the hotrodders use this combination.
NCook
Mar 6, 2017 03:55 PM
Mutilator712
Oct 12, 2016 06:08 PM
351Cleveland C4
Feb 25, 2014 12:31 PM
panman65
Nov 2, 2010 12:33 AM
71mustang
Mar 30, 2002 12:51 PM
