For guys using an AOD
Old Dec 30, 2013 | 07:58 PM
reed1951's Avatar
reed1951
Thumbs up For guys using an AOD
Hey guys, I just saw these 2 videos by monster transmission. They seem to be very detailed with setting up an AOD with a carburetor.
Old Dec 30, 2013 | 09:30 PM
51dueller's Avatar
51dueller
I don't like that they say to adjust the cable for the shift points of the transmission. Those adjustments are to be set in the valve body and governor. The cable is supposed to be set to a certain pressure and then its done.
Old Dec 31, 2013 | 08:43 AM
johnnydevil55's Avatar
johnnydevil55
Are you having trouble with the AOD kickdown? are you using the Lokar kickdown cable? I can help you out or at least try.
Old Dec 31, 2013 | 08:53 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Exactly, it isn't directly a "kickdown" cable (or linkage, on the older ones). It's a control signal. Dire consequences if not correct.
Old Dec 31, 2013 | 11:36 AM
ben73058's Avatar
ben73058
Hey Reed,
Hmmm.. Personally I'd just adjust that cable to get the pressure right. You can do really small adjustments to it but don't go higher than the pressure spec. The Clutch Pack & Governor set the shift points or go with a Solid Throttle Body.
Our experience with Monster wasn't all that great. If you need a warranty I would recommend using a local transmission shop. Monster didn't honor their warranty & were pretty useless. I would look at Baumann Engineering & Silver Fox for guidance on AOD's.
Ben in Austin
1950 F1
reed1951's Avatar
reed1951
I totally ment to put something about that in my first post, I agree. Everything looked good up untill he started talking about adjusting shift points. Here is a link to Lokars instructions on the setup including the line pressure you need.
http://www.lokar.com/downloads/pdf-i...D-Kickdown.pdf
Old Jan 2, 2014 | 05:50 PM
52 Ford F1's Avatar
52 Ford F1
thanks for sharing the resource and the warnings.
jk080
Sep 14, 2009 04:31 PM
pipman76
Engine Swaps
May 28, 2009 10:27 PM
gov2mod
1978 - 1996 Big Bronco
Sep 26, 2005 12:11 AM
71mustang
Mar 30, 2002 12:51 PM
