DEF at the Pump
Old Sep 23, 2020 | 10:01 PM
Thornhill's Avatar
Thornhill
DEF at the Pump
I have 1/2 tank on my DEF and decided to try out a trucker's station (TA-Petrol) because I happened to be in the area (no stations local to me). I waited in line, got to the pump, went inside to pay, came out and found there was only one nozzle for both diesel and DEF. The pump nozzle, of course, doesn't fit. So, I went back inside, canceled my pump and bought a 2.5 gal jug.
So, my question... I've seen adapters for nozzles, but I thought those were magnetic for shut-off purposes. Are those adapters also for situations where there's only one larger nozzle?
Thanks to all for any pointers!
Chris
Old Sep 23, 2020 | 10:11 PM
jsukey's Avatar
jsukey
They won't be the same nozzle. There is usually a small, sometimes iconspicuous nozzle for the DEF at truckstops. They're almost always blue, similar to the pic below.
Old Sep 23, 2020 | 10:27 PM
Rtaylor522's Avatar
Rtaylor522
good think you CNX the order. Never going to be the same nozzle. It was probably hiding behind a black flap you didn’t notice. They don’t usually hang out there “on” the pump. Once you find it you’ll never miss it.
Old Sep 23, 2020 | 10:30 PM
jsukey's Avatar
jsukey
If you look closely at the pic I posted, you'll see the black flap that Rtaylor522 is referring to. It's lifted up in that pic.
Old Sep 23, 2020 | 10:36 PM
Thornhill's Avatar
Thornhill
There is a black panel where it looked like one existed. I asked when I went inside and they said they didn’t have a different nozzle.
Old Sep 23, 2020 | 10:40 PM
Rtaylor522's Avatar
Rtaylor522
I could be wrong, but this sure sounds like you avoided ruining your emissions system. Can you imagine a diesel pump so clean that you could Shoot DEF through it right after filling up with no wash out?
Old Sep 23, 2020 | 10:45 PM
jsukey's Avatar
jsukey
Hahaha! Think I would be more worried about shooting a hose full of DEF into my fuel tank and ruining my engine before the emissions junk!
Sounds like the handle and hose were just missing is all.
Old Sep 23, 2020 | 11:00 PM
Thornhill's Avatar
Thornhill
Yeah, had me scratching my head. I’m going to call the station and see if I can get an answer.
thanks to all for confirming my thoughts.
Old Sep 24, 2020 | 05:27 AM
senix's Avatar
senix
I have always seen the def in an enclosed pump like the pics above. Sometimes is just a cover your lift or behind and plastic lid to lift.
I personally only need def every 4-5K so It has, in the last 7 years, always been my practice to fill using the 2.5 gal jugs at a different time from fueling.
Less chances of mistakes.
stan'37
Modular V10 (6.8l)
Dec 19, 2013 09:15 PM
robindanner
Dec 13, 2007 12:32 PM
MikeSDK
27
Sep 2, 2006 05:46 PM
jake00
General Automotive Discussion
21
Nov 10, 2005 07:16 PM
V10KLZZ71S
Garage & Workshop
Dec 21, 2002 06:13 PM
