Has anyone taken it out for some reason? I'm trying to find a clever place for a gamecube, and I think inside there might be the spot - slice it, put a hinge on it so you can open it, and it might work well. However, if it's solid or there's just no room it wont work!
Is that white support thing completely necessary? I want to cut out the part that has a black box around it - anyone think it's too terrible of an idea?
Here's an alternative view:
Also, should this wiring harness look like this?!
Also since this top piece comes off, I wouldn't have to do ANY cutting, could simply put a hinge on the front of it, remove all the clips (except for the back one) and put one of those lift arms on it if I want!
Thanks again
