crown vic front end
Old Sep 19, 2020 | 05:08 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
crown vic front end
my friend has a 51 ford f1 and he wants to know what is a good year crown vic front end to use on his 51,and what is a fair price to pay for it ?
Old Sep 19, 2020 | 07:10 PM
Old F1's Avatar
Old F1
There is none, ...unless it is narrowed, (very difficult to do ) as it is too wide.
This company makes one (1200..00 usd) https://team321.com/ncv-page/
some info: https://www.ford-trucks.com/forums/1...-victoria.html
Please try a google search: mega info is available
Old Sep 19, 2020 | 10:09 PM
52 Merc's Avatar
52 Merc
I would concur with Old F1. The Crown Vic unit people use is from 03 and newer with the bolt on aluminum crossmember. It's fine in later model vehicles, but our old trucks are considerably narrower, and the CV unit is about 6" too wide to fit in a 48-52 Ford truck. There are much better options to add IFS to our older trucks.
Old Sep 19, 2020 | 10:42 PM
ben73058's Avatar
ben73058
Hey Bob,
Most guys going the salvage route use a Jaguar front end as it's
just exactly the right width for our early F1 trucks. The Crown Vic is so wide there
just aren't many wheels that will fit in the fenders.
Ben in Austin
1950 F1
Old Sep 19, 2020 | 11:34 PM
burnettd01's Avatar
burnettd01
Hi Bob
I agree that the CV front end is not worth the time nor trouble. The 85 and older Jag XJ6 or 12 is a good way to go. Bolts on with home made brackets. Here are a couple of photos of my 51 f1.
Hope this helps
Dan
Old Sep 20, 2020 | 02:27 AM
seaves46's Avatar
seaves46
Nice work Dan .
Old Sep 20, 2020 | 05:12 PM
HILLBILLY BOB
thanks for the info on the vic ifs. I told him to go with the jag but he does not want that.he wants everything to be all ford.this way he can use all ford tires and rims. what can i tell you,i tried to talk him into the jag,but no luck.thanks guys
Old Sep 20, 2020 | 07:03 PM
burnettd01's Avatar
burnettd01
Bob
Tell your friend that he can always have the Jag front hubs and rotors refilled to a ford bolt pattern.
Still cheeper than a MII front end.
Old Sep 20, 2020 | 07:04 PM
burnettd01's Avatar
burnettd01
Redrilled to ford specs.
dam auto correct
Old Sep 20, 2020 | 07:17 PM
Old F1's Avatar
Old F1
[QUOTE=HILLBILLY BOB;19488629 he wants everything to be all ford.this way he can use all ford tires and rims. [/QUOTE]
I think that a Mustang II is a Ford ? (even when a re-manufactured upgraded part)
That is the best choice by far, ... and it even comes with ford wheel bolt pattern.
Old Sep 20, 2020 | 08:17 PM
EBEAR's Avatar
EBEAR
I'm sure someone will correct me if I'm wrong but aren't the jags the same as ford ?
Old Sep 20, 2020 | 08:34 PM
52 Merc's Avatar
52 Merc
Ford owned Jaguar for a time, so one could make a case, even if it might be a stretch, that one could have a jag front end and still call it all Ford.
Personally, I'd make the case, but I'm also about wacky enough that I'd have to have the rotors redrilled 'cause that 4 3/4 bolt pattern would drive me nuts.
Old Sep 25, 2020 | 05:35 PM
HILLBILLY BOB
well my friend says that he still likes the crown vic.,and yes he knows it is to wide,but a welder friend of his told him that he could cut it and weld it so that it would fit his f1.i told him that he is crazy.i have not heard from him since.
Old Sep 26, 2020 | 02:46 AM
seaves46's Avatar
seaves46
It's not that easy though .
Once the crossmember is narrowed the steering rack needs to also be done .
And if it's not done correctly so the geometry isn't messed up he will suffer from bump steer and other issues .
Old Sep 26, 2020 | 12:19 PM
52 Merc's Avatar
52 Merc
Exactly. I've found in my travels the world is full of industrial welders who say it's easy to cut and weld things, but they have no clue what it takes to work on automotive sheet metal or, as Scott mentioned, any comprehension of suspension geometry. I've seen the carnage left behind by the uninitiated.
