302 Swap or not?
302 Swap or not?
okay heres the deal. ihave a 2wd 94 ranger with a 2.3 that has seen its better days. in the next year i will probly have to have some sort of a new motor. i also have a 91 f250 2wd that i am getting rid of. the body is rusted and as it is a 2wd pickup there not worth a whole lot around here. the 302 engine is not in terrible condition. it runsand drives good. auto trans has a little trouble but once it warms up it is fine. question is do you think if i cant get 1000 out of it or just sell it to a junkyard for a few 100 and keep mthe motor to put in my ranger? will this engine have the correct oil pan and headers for my application? also iknow the older 302's fit but what about these new ones with the great big fuelie intake on top?thanks
the headers and pan will not work.you will need a fox body oil pan and a conversion header,advance adapters has them and all the the stuff you will need.if the 302 is going to left fuel injected then there will need to be allot of electrical stuff done,but dont let it stop you.as for the intake i know if you use a mustang or explorer intake it will fit under the hood but i dont think the truck intake will fit.let me know if there is any thing ells.
p.s. a v8 ranger is much cooler than a 2.3
my cousin did this very swap only he used a mustang engine. i beleive he had to get the explorer intake to make things work ok. if you arent up on electronics very well this efi will be a major headache, but it can be done. e-mail me if ya have any questions and ill help ya out. good luck.
if i wanted to put a carberator on my 302 what would need to be done. just a manifold and a carb or am i gonna need adapters of some sort to put the manifold on? can i just get a manifold of of an older 302 and it bolt right up? also with wiring how do i hook upo things like my instrument panel, vent, heate, radioetc?
yes all 302 manifolds will work mine is a roller cam 5.0 with a carb on it.your vents and heat and radio are un affected but guages could be hard,i put aftermarket guages in mine.if you choose to go efi use the mustang manifold and ford motorsports sels a vary simple haness and computer to swap it in,it is also available from summit racing,that is the one i used on my 92 5.0 explorer.
do you think i would be able to retain my factory gauges somehow? im not sure exactly how theyhookup but i would like to keep my fuel , temp, oil press, and batery gauge as well as the speedo. as for check engine lights and things like that im not real concerned. also things like headlights and tailights are hooked up through the fuse box under the dash right? does that box have one positive wire running to it to power all that stuff and then just ground at the accesory? im not sure if thats how these elctronics work or not? any help from u guys would be big help. thanks
