Recently bought Dennis Carpenter Explorer side emblems for my truck, purchased through LMC. The emblems only came with two barrel clips. Is this correct? I expected there to be 6 total (3 for each side). Anyone have experience with this and can let me know if I should contact LMC?
I never had the original emblem, but there are three holes in my bed above the rear side light. The mounting points fit fine. Just not sure if I need more barrel clips? Thank you.
Well normally on a cowl badge or hood letters you get enough barrel clips to match the # of mount pins on the emblem. 3 bed holes and 2 mount pins on the repop emblem, interesting. Let's hope the the 3 bed holes at least line up with your 2 mount pins on the emblem. I would be calling LMC for at least some more barrel clips.
