Pinion End Play Question
Old Sep 17, 2020 | 07:33 AM
624WD's Avatar
624WD
I posted a question about rebuilding a 9" differential in the driveline and transmission forum. I need some help about adjusting the looseness of a pinion on the ring gear. Don't know if this forum is active but if you have knowledge about adjusting lash and these ...I could use your insight. tom
Old Sep 17, 2020 | 08:13 AM
chiefdave's Avatar
chiefdave
Adjusting the gear lash properly requires some specialized measuring equipment that most of us home mechanics don't have. You might want to assemble your diff and take it to a specialty shop for final adjustment. Gear lash is should be .008-.012 so you only have .004 to work with.
Old Sep 17, 2020 | 08:40 AM
624WD's Avatar
624WD
thanks. that explains it. Appreciate the response. tom
Old Sep 17, 2020 | 05:46 PM
john jamieson's Avatar
john jamieson
There are some good you-tube vids on doing it
624WD
Sep 17, 2020 05:39 PM
mtntop1
Oct 14, 2016 05:33 PM
Tomahawk2506
Aug 23, 2012 11:22 PM
allen720
Florida Chapter
Apr 13, 2012 07:47 PM
glasseater
Jun 4, 2011 11:34 AM
