2001 e250 pulls left
Old Sep 15, 2020 | 05:00 PM
Duncan Scott Millar's Avatar
Duncan Scott Millar
Hi all, my 2001 E-250 pulls to the left at highway speeds, I measured and I have about 1/4 tow out. No recent pot holes and no brake dragging. Ball joints are tight. Any ideas would be appreciated.
Old Sep 16, 2020 | 05:01 AM
JWA's Avatar
JWA
Tire pressure or a caliper beginning to not fully release when the brake pedal is released. Does it "dive" to one side or the other under braking? Have you inspected the caliper, flexible brake line, the pads or the rotor run-out or front inner and outer wheel bearings?
Old Sep 16, 2020 | 08:07 AM
Duncan Scott Millar
I’ve checked for brake drag. Jacked the truck up and check for wheel drag and lose front end parts, seems more like an alignment issue. I found the alignment specs but I’m trying to check it in my driveway with a tape measure, it has a 1/4 - 3/8 toe out.
Old Sep 17, 2020 | 04:24 AM
JWA's Avatar
JWA
You're not checking any important aspect of front suspension alignment with it parked in a driveway. Toe setting is but one part of the complete set of specifications which need to be measured properly with equipment designed for that operation.
Old Sep 17, 2020 | 04:58 PM
Duncan Scott Millar
Having problems finding any specs that are in SAE. Everything is in degrees
Old Sep 17, 2020 | 05:53 PM
coolfeet's Avatar
coolfeet
Bring it to an alignment shop that has the correct equipment to measure what is off. The driveway test says you have a problem. It's worth the price to get the report. Before I take my vehicle to the alignment shop, I check tie rods, ball joints, wheel bearing torque, tire pressure. I replace everything that is worn. A good alignment will run about $100. You will pay more if you arrive with worn out parts and have to pay the shop rate for installation.
How did you check the ball joints?
Old Sep 17, 2020 | 07:48 PM
Duncan Scott Millar
So I found a problem. Started measuring heights today and the right rear was low.
had a look underneath and this is what I found, thank you Ford
Old Sep 18, 2020 | 04:35 AM
JWA's Avatar
JWA
How long did that go unnoticed? Holy cripes----not necessarily Ford's fault though.......
My own '03 E250 extended body had the same rust issues with rear spring hangers but it was caught long before it broke away as shown here.
Not sure where this van has lived most of its life but that's one huge amount of rust on the frame and other attachment parts. It looks as though the van has sat for very long periods of time. I'd suggest checking the entire frame and underside of the body for more severe rust issues.
Old Sep 18, 2020 | 08:30 AM
Duncan Scott Millar
It was a Kentucky vehicle used by a cable company before I got a hold of it 14 years ago. The only time it has set is in my concrete driveway.
Old Sep 18, 2020 | 12:56 PM
Zoidberg's Avatar
Zoidberg
I had a very similar failure on my '94 F150 that lived around Columbus, Ohio for most of it's life.
One rear shackle had already rusted through by the time I took ownership and I replaced both of the rears since they got most of the road salt spray.
I'd definitely check and probably replace the brake lines now, I didn't and they rusted through not long after...
Lb91696
Jul 31, 2018 10:26 PM
Weston James Randorf
General Automotive Discussion
Jul 8, 2015 07:31 PM
OZX1
1997 - 2003 F150
47
Feb 5, 2007 11:35 PM
umbraun9
1983 - 2012 Ranger & B-Series
Sep 24, 2004 01:06 AM
lucki
Jun 28, 2002 11:17 AM
