Fluid Film question
Old Sep 15, 2020 | 06:37 AM
fordman19762003's Avatar
fordman19762003
Fluid Film question
Normally I apply fluid film twice a year, in the spring after the salt is off the roads and again in the fall before it gets cold. This summer we haven't had much rain and I still got a pretty decent coating of the fluid film/grime underneath and was trying to decide if I should just touch up around the axles and leave the rest alone or do my normal routine and wash it all off and start over?
Old Sep 15, 2020 | 06:51 AM
BillyE's Avatar
BillyE
Don’t see how anyone could answer that question for you, but if this is what you need to do to prevent rust, I’d do the normal routine.
Old Sep 15, 2020 | 08:00 AM
morleyz's Avatar
morleyz
Cheap insurance. I'd do it anyway.
Old Sep 17, 2020 | 10:51 AM
seventyseven250's Avatar
seventyseven250
Why bother washing it off? Also, what do you use to apply it? I'm assuming you buy the gallon can and spray it with something. Or do you use the aerosol can?
Old Sep 17, 2020 | 12:58 PM
senix's Avatar
senix
I dont' wash it off. I get the compressor out and shoot it again.
Old Sep 17, 2020 | 07:18 PM
fordman19762003
I use the aerosol cans for inside the doors/rockers and any other hard to reach areas and use the thicker bulk stuff for everywhere else.
For applying it I use the sprayer that Fluid Film sells. I'm thinking about getting the "Pro" version that has the long hose to make it easier to reach tight areas and it would work better and be cheaper for doing inside the frames than using the aerosol.
Old Sep 19, 2020 | 08:48 PM
Mitch7c's Avatar
Mitch7c
Whats your prep procedure for every year? light degreaser and wash or? Wanting to do this since i just bought a 19 and don't want it to rust in the salt belt of illinois
Old Sep 19, 2020 | 09:13 PM
senix's Avatar
senix
car wash good spray and rinse, then let dry
Should be good after that
Old Sep 20, 2020 | 08:12 AM
T diesel's Avatar
T diesel
If you can find a Krown location nearby, I highly recommended you consider it.
Old Sep 20, 2020 | 08:33 AM
George in NH's Avatar
George in NH
I've been using Fluid Film on my trucks and tractor for over 20 years. I've never cleaned off the previous application, I just spray it on in the fall and spring. That includes my old Land Rover Defender 90...I owned it for 18 years / 300K miles...Rovers are notorious for frame corrosion because of the steel frame with aluminum body causing galvanic corrosion and I never had a corrosion issue on it, or any of my other trucks.
Old Sep 20, 2020 | 08:48 AM
sPickins's Avatar
sPickins
Would love to see a pic of the "preserved" LR frame and fenders. I used FF once on my FJ Cruiser and then brought it to a shop for some suspension work. They said they wouldn't work on it with all that "crap" sprayed on. LOLOLOL!!
Old Sep 20, 2020 | 08:51 AM
senix's Avatar
senix
They should have been happy to work on it without all the rusted bolts that brake off.
Old Sep 20, 2020 | 09:19 AM
sPickins's Avatar
sPickins
Agreed, their loss!
Old Sep 20, 2020 | 09:59 AM
fordman19762003
I had one shop ask if I had an oil leak when I took my truck in for some warranty work, I said no it's just fluid film. usually I'll warn them ahead of time of what the mess is but I forgot that one time.
Old Sep 20, 2020 | 10:03 AM
fordman19762003
That's good to know. I've always thought I was wasting the stuff when doing my fall application because a lot of the time I still had a nice coating on everything. It takes a long time to get that gooey blend of fluid film and dirt that does the best job of resisting road spray and I hate stripping it down and starting over.
In the spring I would still wash the old off and start over just to make sure I get all the salt residue off.
Qwazert
6.2L V8
Jul 13, 2020 12:16 AM
unibody62
2009 - 2014 F150
Feb 1, 2020 04:09 PM
#1hawkeyesfan
Sep 18, 2019 08:23 PM
Corallis
Apr 30, 2015 02:40 PM
KLINE925
Oct 8, 2006 10:51 PM
