Oil Consumption
Old Sep 15, 2020 | 06:06 AM
leetudor's Avatar
leetudor
Oil Consumption
I have an 2016 with 116,000 miles on it. Changed my oil on Sunday with 6 months and 7,500 since the last change. I had poured in 13 quarts 6 months ago but only drained out 11 quarts from the pan and the filter. Would that normal consumption of oil?
Old Sep 15, 2020 | 09:16 AM
HRTKD's Avatar
HRTKD
Some oil would still be in the oil filter, no matter how well you drained the filter. I would keep an eye on it by checking the dipstick over the next few trips to fill up with diesel.
Old Sep 15, 2020 | 11:48 AM
Overkill2's Avatar
Overkill2
With over 100k miles, there may be more blow by as well as the engine has more wear on it. Just thinking out loud.
Old Sep 15, 2020 | 11:49 AM
leetudor's Avatar
leetudor
I have done it twice and both times have come out to be around 11 quarts. First diesel that I have owned so not sure on usage.
Old Sep 15, 2020 | 03:39 PM
dirthawg's Avatar
dirthawg
My 2016 makes oil!
Old Sep 15, 2020 | 04:09 PM
Just Strokin's Avatar
Just Strokin
2 quarts "used" is considered normal consumption. I would not worry. I would worry about "making oil". "Making oil" is fuel washing by the rings from idling or wear or other causes.
Old Sep 15, 2020 | 04:18 PM
Sailor#10's Avatar
Sailor#10
My 2009 6.4 used to "make" almost 2 quarts of oil between 5,000 miles oil changes. I was always amazed that the amount of fuel dilution didn't result in wiped bearings. The amount of oil "production" never varied over the 110,000 miles I had the truck.
Old Sep 15, 2020 | 04:20 PM
mjs2011's Avatar
mjs2011
Originally Posted by dirthawg
My 2016 makes oil!
Same here, I'm at about 3-3.5% fuel dilution in my oil from the past few Blackstone oil analyses I've done.
Old Sep 15, 2020 | 08:17 PM
FishOnOne's Avatar
FishOnOne
Is the oil reading low on your dipstick? Because if your engine consumed 2 quarts of oil you will definitely notice that on your dipstick.
Old Sep 15, 2020 | 08:20 PM
leetudor's Avatar
leetudor
Actually did not check it. Will start checking now, going to check it after one week and see what I get.
Old Sep 16, 2020 | 05:35 PM
senix's Avatar
senix
weekly checks with the truck in the same spot and direction after an over night cold soak is how I check mine.
biz4two
6.2L V8
Jan 3, 2013 11:49 AM
hardRESET
Oct 23, 2011 06:58 PM
bigbubba87
Oct 19, 2010 07:18 PM
Rambo76
Jun 14, 2009 11:46 AM
Petiboy
1997 - 2003 F150
Oct 30, 2003 07:49 AM
