Newby
Old Sep 15, 2020 | 03:21 AM
Ls1500's Avatar
Ls1500
Newby
Hey guys just picked up a 1958 F500 with a ls1, just wondering if you can buy aftermarket Bailey channelling for the Doors without the aluminium In it.....I was looking at this on eBay ....thoughts?
https://www.ebay.com.au/itm/132550646894
Old Sep 15, 2020 | 06:47 PM
spurredon's Avatar
spurredon
Interesting looking truck. Looks like fun. I have only used the channel with the aluminum so I guess I am not any help.
Old Sep 15, 2020 | 06:48 PM
spurredon's Avatar
spurredon
By the way, welcome to FTE!
Old Sep 15, 2020 | 07:14 PM
Ls1500's Avatar
Ls1500
Made in Australia lol just fitted new vent window rubbers from Dennis carpenters..... nasty fit wouldnt recommend them at all!
Old Sep 15, 2020 | 07:55 PM
DropTheHammer's Avatar
DropTheHammer
Interesting that it has the 1960 grille and hood. The left hand made me double take. Neat ride! The dash pad is good for those brake tests hurts a little less then the metal I'm sure.
As for the seals you installed, I have some and am curious about where the fit issue was for you? Did you pull out the whole assembly?
I've yet to do mine but did take 1 side apart and there is a lot more seals then just the perimeter/ channel part you mention. The new seals also have the little plastic nubs, where it was metal tabs on the original seal, into radius of the main window track, Im not sure the non backed seal would really stay put that easily. The rattlers and vent window seals also seem to set the depth of the division bar and rear of the channel. Theres also glass tape that sets the glass window into the lift track for it all.
Old Sep 15, 2020 | 07:57 PM
DropTheHammer
Also just saw the puke can for the radiator, Good ol' Jim Beam. Funny stuff.
Old Sep 15, 2020 | 08:57 PM
Ls1500's Avatar
Ls1500
Old fire extinguisher airbox
Old Sep 15, 2020 | 09:23 PM
Ls1500's Avatar
Ls1500
hopefully the will settle down, doubt it though
Old Sep 15, 2020 | 09:25 PM
Ls1500's Avatar
Ls1500
yes pulled out the whole assembly
Mabe the rubbers are supposed to be down inside the door? where it’s lifting and gaping, not sure as
my original ones were that bad you couldn’t tell
Old Sep 16, 2020 | 07:55 AM
DropTheHammer
Mine where pretty rough as well. The only thing I’ve seen that seems to be the easy way to seat the thin lip is roving rope the little perimeter so it pulls the lip over. And lots of soapy water. You know, slippery when wet.
Old Sep 16, 2020 | 04:35 PM
Ls1500's Avatar
Ls1500
I used wd40 there’s just not enough lip to go over the edge I just put it down to crap product.
76f350spercamprspeal
1961 - 1963 F100 Unibody
1033
Apr 24, 2025 12:49 AM
Muppy1840
Mar 12, 2020 01:17 AM
85MOTORSPORTXLT
27
Dec 17, 2017 09:57 PM
firstrider
19
Oct 2, 2009 04:23 PM
dave boley
28
Feb 12, 2009 12:58 PM
