Excursion Keys
Old Sep 13, 2020 | 12:13 PM
Out4trout's Avatar
Out4trout
Excursion Keys
Real quick, does anyone have a part number or amazon link for an excursion key blank?
I know they need to be programed. my 2000 7.3 has 2 keys and I want a third as backup. my 2002 v10 only has 1 key and I want at least 1 backup.
After some reading it seems I can program the 2000 7.3, but I will need additional assistance with the 2002 v10. Curious I saw that you can program with forscan, but do you need a special license or something?
Old Sep 13, 2020 | 01:25 PM
rtbrjason's Avatar
rtbrjason
I bought these for mine.
StratTec 597602 H72PT Blank Transponder Ignition Key with Ford Logo for selected Ford, Lincoln & Mercury Vehicles
Amazon Amazon
I had them cut and they work fine. I was unable to program them with Forscan. In order to program with Forscan, you need an extended license. You can get that for a month or two for free.
In my case, the only Key I have is already a copy so I’m not sure if that’s why programming failed or not. I’m hoping the dealership will be able to program them for me. I need a spare and one for a remote start install.
Old Sep 13, 2020 | 05:35 PM
projectSHO89's Avatar
projectSHO89
Get the FREE extended license and finish the job.
It will cost you an hour's labor (plus shop supplies(!)) to get it done at the dealership. Let's see, FREE vs $125-$150. Yeah really tough choice....
Old Sep 14, 2020 | 07:47 AM
unleashd's Avatar
unleashd
I bought these blanks from Amazon. Dealer cut & programmed them for me.
Amazon Amazon
Old Sep 14, 2020 | 12:02 PM
cviss's Avatar
cviss
4wd Low
or you could get one of these
https://www.alibaba.com/product-deta...6ad57a64x7OSlU
Old Sep 14, 2020 | 01:36 PM
Out4trout's Avatar
Out4trout
Originally Posted by cviss
is it literally as easy as get the key cut and then use that little machine to program it? Have you used it?
Old Sep 14, 2020 | 02:40 PM
cviss's Avatar
cviss
4wd Low
Yes get the key cut... and program it ...
The product will tell you what keys are active and not and you can remove the ones that are no longer in use...
You can also program key fobs also...
I used this product for 2000 ford excursion (v10), and 2009 ford expedition, and 2013 jeep wrangler with zero issues.
Old Sep 14, 2020 | 04:32 PM
Out4trout's Avatar
Out4trout
Im going to order the obd2 usb deal for the forscan. I can get that off Amazon. I’ve never ordered from the Alibaba place. Besides that the additional functionality of the forscan seems like a no brainer. I’ve been thinking of getting the connector for my laptop anyhow.
even if you buy the license and the connector I think you’re still at or just below $100
I was kind of bummed that the less expensive Keys posted above took almost 2 weeks shipping. I ended up buying more expensive blanks but they’ll be here by the end of this week when the OBD two arrives.
Old Sep 25, 2020 | 08:48 AM
Out4trout's Avatar
Out4trout
OK. I ordered the blanks from Amazon and got them cut at the local hardware store. it all went fine. This is what I ordered.
Amazon Amazon
I probably over paid and could have used the other cheaper option.... BUT these worked in both my 2000 7.3 and my 2002 v10
I got FORSCAN and the OBD2 connector they recommend. got the free extended license.
I also purchased a set of these Key Fobs:
Amazon Amazon
They were very easy to program and worked great in both vehicles
I first went to the 2002 v10. hooked up the FORSCAN and saw the PATS module. I reviewed the procedure on the FORSCAN website. I selected erase all and program keys and was shocked to see that instead of asking me about the incode and outcode and all that, it told me that there was a 12 minute security delay??
so i waited....kept wiggling the mouse to make sure nothing went to sleep...and finally it said that the other keys were erased and insert 1st key for programing and cycle from run to off to run. and repeat. I did it for the first key, nothing happened, not sure what I was supposed to see happen but nothing occurred. I guess I was looking for the screen that said key programed, enter next key. It never happened. SO then hit ok thinking it would then have me cycle the key....but nope...FORSCAN just exited the module.
LOL
ok so i disconnect and reconnect and go back into PATS...see that I still have keys programed...select erase and program....wait another 12 minutes...same result.
So I go back in and see that now I have zero keys programed! select program...wait another 12 minutes....no idea if it worked...
go back in and I see I have 2 keys programed....
so now I am at least an hour into this 5 minute project and I decide that since I am now in possession of 2 programed keys (I started with only 1) that I would use the vehicle to program my 3rd key. Pulled up the youtube...put in first key, cycle, 2nd key, cycle, 3rd key, cycle.... turn off and used the 3rd key to start vehicle...it worked (I forgot to mention that in between the steps above I did test the keys to confirm if they would start the vehicle or not)
loaded FORSCAN again and opened PATS module, confirmed that there was in fact 3 keys loaded. Wow what an ordeal...LOL
So i guess FORSCAN did work...I was surprised by the "timed access pats requires the diagnostic tester to enter a runtime delay" wait 12 min deal and no confirmation of key being programed, no insert next key to be programed or exit.....etc
definitely if you have 2 keys (which i did not) use the vehicle to program your 3rd....
So after all that I plug into my 2000 7.3. Looking for PATS module....still looking....WTF there is no PATS module....HMMmmmm
I have 2 keys for this vehicle so I figure I will just use the vehicle to program the 3rd...but before i do I try the 3rd UNPROGRAMMED key and varoom...it starts
So I google and search and look around....best I can come up with is that my hydra PHP chip has disabled the PATS function?? I dunno could be.... I do know that the THEFT light always blinks for a little bit of time then goes away ever since I chipped it...never really bothered me, so i just ignore it...emailed gearhead, waiting to hear back...
I sent the log info to FORSCAN and asked them what they think...they responded that it would appear, from the log data, that the vehicle is not equipped with PATS...
so for the heck of it, i just did the procedure to program a 3rd key using the vehicle...i know it did nothing, but at least I feel like I programed the key..lol
so i wanted to write this up in case someone came across a similar issue...
Old Sep 25, 2020 | 09:11 AM
rtbrjason's Avatar
rtbrjason
I didn’t get Forscan to work, but I only tried to program a 2nd key. I’m too afraid to choose the option to delete all keys and program from scratch. I at least have one working key for now.
Old Sep 25, 2020 | 09:24 AM
Out4trout's Avatar
Out4trout
if you have the extended license, you could load the PATS module, see how many keys are programmed, then select the "program" another key thing NOT "erase and program"....wait for 12 minutes?? did it have you do that like it did me? then do what it says on the screen to program the key...insert, cycle, insert, cycle, etc...then disconnect and reload PATS...if it says that you have an additional key programmed you are set...
Old Sep 25, 2020 | 09:29 AM
rtbrjason's Avatar
rtbrjason
It showed 4 keys programmed, but only one came with the truck. I tried 5-6 times to program an additional key, waiting 12-15 mins each time but it always returned an error that programming failed. I tried the new keys anyway and they won’t start the truck. I thought maybe 4 was the maximum and that was the problem, but Pats doesn’t appear to have a limit.
My extended license has since expired. I think I’d have to pay for the extended license at this point. Not sure if I’ll try the delete all and program or not. If that fails, the truck will be stuck in the driveway. Mine is an 02 as well.
Old Sep 25, 2020 | 02:46 PM
projectSHO89
A 2000-2002 is way too old for incode/outcode security access. You have to wait the 12 minutes for security access.
If it's any consolation, dealer techs have had to go through that same wait since PATS was introduced almost 25 years ago.
AbbyExcursion
Jun 16, 2020 07:37 AM
bearintex
Dec 19, 2017 12:51 PM
bjvagts
Modular V10 (6.8l)
Oct 21, 2014 10:19 AM
bjvagts
Oct 9, 2014 10:22 PM
Superduty krazy
30
Jul 25, 2008 02:18 PM
