DRL
Old Sep 12, 2020 | 05:44 PM
Tjmartin114's Avatar
Tjmartin114
DRL
Ok, so, I've seen older threads with this question and need an update. I've searched the settings and cannot locate a way to turn off the DRL. I have the 2019 Black Out Edition f250 and I've NEVER EVER had a use for this. It kinda takes away the animal characteristics of the truck. Relay removal? Anything I'll try. One last tg Hong and I think its important to say, the truck was built in Kentucky, but was delivered to Canada. Any help I'd very much appreciate. Thanks
Old Sep 12, 2020 | 06:14 PM
Just Strokin's Avatar
Just Strokin
You should be able to go into your Information Display settings under Vehicle and you should be able to turn off DRL. See page 115 and 119 of your owner manual. If no manual you can download one here...
Ford Owners Manuals Search Results
Old Sep 13, 2020 | 08:37 AM
Tjmartin114
yep, went into settings. As it shows in the manual under lights... I am able to adjust the timer for the delay, but the on/off setting for the DRL's are not present. Like I said in the previous post, Canadian vehicles have mandatory DRL's. So being this truck was destined to the great white north I'm not able to easily shut them down.
Old Sep 13, 2020 | 08:43 AM
Just Strokin
I would suggest you go over to the 2017-2019 forum and ask your question instead of the 6.7 Engine forum.
https://www.ford-trucks.com/forums/forum279/
Old Sep 13, 2020 | 10:46 PM
jetskier's Avatar
jetskier
You can turn them off using ForScan. It's in the BCM line 726-50-01.
See this spreadsheet for the particular values.
https://docs.google.com/spreadsheets...s1s/edit#gid=0
should be set to: xxxx 01xx xxxx for master DRL disable
Old Sep 14, 2020 | 10:33 AM
Flitastic's Avatar
Flitastic
Am I missing something here or can't you just turn the **** of???? I also have a 2019 and always used my DRLs but decided it wasn't really necessary either so I turned the **** all the way left from " Auto" to "Off" problem solved. What am I missing? Thanks!
Old Sep 14, 2020 | 11:31 AM
Just Strokin
Might not be that easy on a truck sold for use in Canada. DRL's are mandatory.
Old Sep 14, 2020 | 11:51 AM
Tjmartin114
This looks to be the surest suggestion, however I'm not equipped personally to go through the steps required. Looks difficult and I'm not the one to one making changes there. Thank you for the answer.
Old Sep 14, 2020 | 01:34 PM
Flitastic's Avatar
Flitastic
OHHHHHHHHHHHH yea, makes sense!!!
jdbanks
Texas Chapter
Apr 16, 2012 01:57 AM
jseim44
Nebraska Chapter
26
Sep 3, 2008 05:37 PM
indebt
28
Jun 27, 2008 05:23 PM
wparente
Mar 3, 2007 03:15 PM
