No code. Coolant temperature
Old Sep 12, 2020 | 05:20 PM
Msober1's Avatar
Msober1
Hello and ty for any help in advance. 2006 Explorer 4.0 EB. First off problem is coolant temperature will not go above 175 180*. New 2 CTS, new CTS housing at the same time. Test both new sensors and good resistance with temperature change. Test connections at CTS and PCM (Pin 18) both good and normal resistance from PCM connector to CTS connection. Scan tool CTS temp reading cold engine 75* KOEO and then KOER 75* and climbing to 175* winter or summer with AC running. Would like to be confident it’s my PCM. Has anyone used a rebuilder that is good. Sorry I forgot to say what thermostat is in it now a 195 stat.
Old Sep 15, 2020 | 09:19 PM
HELMUT RONER's Avatar
HELMUT RONER
Is the new sensor a Motorcraft or parts store brand?
Old Sep 16, 2020 | 10:09 AM
Msober1's Avatar
Msober1
It is a parts store brand. I did test it against the engine temperature and it was ok. Resistance follows water temperature.
Old Sep 21, 2020 | 08:26 AM
Number4's Avatar
Number4
Thermostat stuck open?
Old Sep 22, 2020 | 09:42 AM
Msober1's Avatar
Msober1
no the stat is ok. I have more than enough heat in the heater. I tested the heater lines and they were 180 190*. This has been going on for more than a year. I had this problem before I changed the thermostat housing but it had a 170* stat in it. I changed it for a 192* stat. Ty for your reply
Old Sep 23, 2020 | 12:53 AM
Number4's Avatar
Number4
After a good run, try using one of those hand held laser temp readers on the upper/lower coolant hoses.
It’s not possible to be running below 196° on a 90° day. Or even high 80’s. Not sure what your highest temps have been.
on a 88° day, waiting in a drive through, I’m hitting 206° coolant temps.
BKeathB
Oct 26, 2016 11:21 AM
Ken_C
Feb 11, 2013 08:01 AM
john19999
Nov 21, 2010 08:26 AM
1994diesel
Jun 8, 2008 09:04 AM
Ranger88Den
1983 - 2012 Ranger & B-Series
May 3, 2005 10:14 AM
