Engine coolant temp. test
Old May 2, 2005 | 11:54 AM
Ranger88Den's Avatar
Ranger88Den
1988 Ranger, 2.9, auto has rough idle and temp. guage never rises to normal. Pulled koeo, cont. & koer codes and received 21 code (engine coolant temp. sensor out of range). I plan to change out thermostat, however, is there a test for the ECT sensor? Any other ideas?
Thanks D
Old May 2, 2005 | 07:54 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!!
2.07k ohms at 212'f & 37.0k ohms at 68'f should give you an idea if it's good but if your not getting the engine up to temperature because of a bad thermostat you can get the code so I would fix the engine temperature problem first.
Old May 2, 2005 | 09:08 PM
Rockledge's Avatar
Rockledge
Welcome!
You can get that code if the engine isn't up to operating temperature when you so the EEC test. Make sure you pull the codes on a warm engine.
Regarding testing the ECT, it's pretty straightforward: ECT Operation & Testing
Old May 3, 2005 | 10:14 AM
Ranger88Den
Thank you for responding Ken00 & Rockledge. I ran the engine for approx. 20 min prior to test. I will change out the thermostat and proceed with ECT sensor test if necessary.
Thanks again, D
XLRANGER94
Jan 13, 2010 05:24 PM
LoneWolf0510
Dec 3, 2005 10:00 AM
Darthange
29
Feb 7, 2005 04:27 AM
