Bent valve replacement
Old Sep 12, 2020 | 02:28 PM
Brian Cahill's Avatar
Brian Cahill
Timing gear went out a few months back. No spark, no compression, camshaft does not spin. Gears are bad. Engine has bent valves.
As a preface this engine has 201,000 miles. I bought it at 105,000, soon after an engine rebuild. I pulled a 2800 lb travel trailer on a couple big trips the past couple summers and it finally gave out.
I am really fond of this truck, as it has been well maintained.
So, rebuild or new remanufactured is the options. Any suggestions. I am not the mechanic. What are the likely costs involved.
Old Sep 12, 2020 | 02:33 PM
Brian Cahill
Bent valves
How much to replace bent valves on 4.9 300 manual.
Timing gears bad too.
Engine has 201,000. Was rebuilt at 105,000.
Is Engine replacement better option?
Old Sep 12, 2020 | 09:03 PM
donjamer's Avatar
donjamer
Duplicate threads merged..
What vehicle is this associated with or what size engine..
I will move to appropriate forum when you let us know
Old Sep 12, 2020 | 09:56 PM
Brian Cahill
1988 300 4.9 efi manual air in heads
1988 300 4.9 manual air in heads
Old Sep 12, 2020 | 11:03 PM
85e150's Avatar
85e150
If you are not a mechanic, start looking for a reman'd engine.
Bent valves may have nicked up the piston or cylinder wall. You won't really know that until you pull the head.
The price for a reman will tell you about what the repairs will be. Your engine has 100k+ on it, so any reman you do or have done will involve lots of new parts anyway.
All of that is unknown until there is a tear down.
Old Sep 13, 2020 | 10:15 AM
Brian Cahill
Tear down or reman'd?
Appreciate your recommendations. I can get a good deal on a reman'd. $1500 plus $300 for kit. Still at least $1400 or more to install.
Old Sep 13, 2020 | 01:50 PM
AbandonedBronco's Avatar
AbandonedBronco
What makes you think it has bent valves?
The 300/4.9 is a non-interference engine, so if the timing gears go, it just spins around and dies.
Pull the oil pan off, clean out the shredded timing gear bits and pieces so they don't clog the oil pump, put on new timing gears, and fire it back up.
If you know it has bent valves, it's still a non-interference engine. Bent valves won't touch the pistons/piston walls. You can pull the head and just have the head rebuilt with new valves.
Old Sep 13, 2020 | 01:58 PM
FuzzFace2's Avatar
FuzzFace2
What is the 1500 + 300 is that to rebuild yours?
or is that for the reman and then what is the 300 for?
Then you have 1400 for R&R I am guessing?
So who said the valves are bent?
I did not think the 300 motor or any of the OHV Ford motors bent valves if the gears (on a six) chain went bad?
The motor will turn over faster than normal because the valve timing is not right.
The shop that might have said bent valves spends to much time on the newer OHC motors and yes they will bend valves if a belt lets go.
I also find it hard that the 300 six gears, no chain, went bad in under 100K but guess it could happen?
Dave ----
Old Sep 13, 2020 | 02:19 PM
Brian Cahill
Noninterference engine reply
sounds like the good news I was hoping to hear.
Because of the way it went out caused me to wonder. Just heard a rather minor snap and no other sounds. It reminded me of the non sound when my VW Betts timing belt went out.
The mechanic I brought to wrote that it had no spark and no compression, bad timing gear and possibly bent valves.
I will surely follow up.
Thanks
Bpcahill
Old Sep 13, 2020 | 03:41 PM
FuzzFace2's Avatar
FuzzFace2
I see now that AB posted his just before my post and I was like What??
Did I miss the post before mine? Don't think so because of the times.
That is 2 that say no bent valves
Dave ----
Old Sep 13, 2020 | 03:53 PM
Brian Cahill
No bent valves
I certainly am hopeful now to get this truck up and running. Thanks for advice
bpcahill
thegrizzly1
New Member Introductions
Dec 9, 2016 09:44 AM
