Deep for shallow core (frost) plug
Old Sep 11, 2020 | 04:52 PM
94ZR580's Avatar
94ZR580
My engine, 5.0l, sprung a leak at the rear most core plug (frost plug) on the right side, right above the starter. The only 1 1/2" core plug I could find in town is a deep one and I believe what is typically installed in this location is a shallow plug. Can I use a deep plug in place of a shallow plug? I would expect to leave the excess depth outside the block, not set it flush like you normally would. OK, or big problem?
Old Sep 11, 2020 | 05:36 PM
aquartlow's Avatar
aquartlow
The deep core plugs are MUCH easier to install, just don't need to install them at full depth. Place red lock-tite on O.D. on core plug prior to installation, I drive them in so they are flush with block not flush with recess in block(this keeps them square and not fully driven in). Try to get brass ones if possible, while starter is out, you may want to look at replacing the next one forward as well, may save some "down the road" aggravation. Hope this helps.
Old Sep 11, 2020 | 06:15 PM
94ZR580's Avatar
94ZR580
Great help, Thanks! I hope to get into it this weekend.
Old Sep 12, 2020 | 10:42 AM
kevinv10's Avatar
kevinv10
My previous 5.0 used 1" plugs. Are you sure yours are 1 1/2"?
Old Sep 13, 2020 | 12:09 AM
94ZR580's Avatar
94ZR580
Yes, I'm sure. All small blocks used the 1 1/2" core plugs on the side of the block from the 289 on up. There are some smaller gallery plugs, but I think they are smaller than 1".
Old Sep 13, 2020 | 12:19 AM
94ZR580's Avatar
94ZR580
I had some good news when I got under the truck and got the starter out of the way. The problem was with the block heater that was installed in the rear core plug hole. A new block heater is easier to install in this case, than driving in a new core plug. The clamp wings had broken and the o-ring was trashed. I don't know how it got like that, but better now than at 40 below when I need the heater.
Old block heater
New heater installed
Gunnerboy
Mar 27, 2017 12:32 PM
wtroger
Oct 31, 2016 09:08 PM
Special Ed
Nov 11, 2011 10:42 AM
nickh
Feb 15, 2009 06:35 PM
