Upfitter / wiring
Old Sep 11, 2020 | 04:28 PM
ksignorini's Avatar
ksignorini
Upfitter / wiring
By the description in the manual, there is upfitter switch wiring ready to tie-into "...under the instrument panel on the right-hand side of the passenger footwell." When I open that up, I find a bundle of wires there, but they don't appear to be for the upfitter switches.
Where are the upfitter wires?
What are the ones I found?
(Manual page and picture of what I found attached.)
Old Sep 11, 2020 | 04:46 PM
ksignorini's Avatar
ksignorini
Darn. Searching for "upfitter" in the forum didn't find any discussion. After posting this, I found the following thread. Sorry about the extra thread for nothing.
https://www.ford-trucks.com/forums/1...-switches.html
Old Sep 11, 2020 | 04:49 PM
e23barton's Avatar
e23barton
Did you find them? Mine are on the driver side of the engine bay, tucked right behind the relay box.
Old Sep 11, 2020 | 05:04 PM
ksignorini's Avatar
ksignorini
Aha! I found them. Here's what it all looks like on a 2020 F350. It a bundle, all taped up on the underside of the upfitter fuse box. Looks like they just couldn't be bothered to actually pull them into the cab and leave them in the passenger footwell as the manual indicates.
To get at the bundle, I unlatched the fuse box and pulled it up. (I did not untape/unbundle the wires, but I'm sure that's what you see in my pics.)
Old Sep 11, 2020 | 06:31 PM
stryder's Avatar
stryder
Yes,those are the upfitter wires taped and bundled coming out the bottom of the fuse box. The bundle you found next to fuse panel inside the cab are for the PTO controls. Most common use is the high idle mod which there are several threads covering the process.
Old Sep 11, 2020 | 09:21 PM
Marks2017's Avatar
Marks2017
So Im trying to understand this. I keep getting confused on these ‘20. The wires that are under the fuse box in the pics are ready to tie a wire into for an accessory and not the ones inside the cab ?
Old Sep 12, 2020 | 11:14 PM
Justvisiting1's Avatar
Justvisiting1
On the 17 to 19's. The main upfitter wires are the ones under the fuse box drivers side engine compartment.
the ones inside the passenger kick panel are just feed throughs from the engine compartment.
so you dont have to make a way in.
and would have to run a wire from the drivers side wires to the passenger side and tie to the correct color and so on.
Theres a thread about taking out the passenger side wheel well to have easier access to make the connection.
Old Sep 12, 2020 | 11:55 PM
Justvisiting1
So it seems the 20's are different...
https://www.ford-trucks.com/forums/1...ch-wiring.html
bbronco66
Nov 9, 2024 06:50 PM
scottz99
Jan 5, 2021 11:41 AM
Syphlyn
May 8, 2020 12:37 PM
Jim Craig
Aug 23, 2019 02:14 AM
drizzie27
Mar 28, 2012 06:08 PM
