Sponsored by: Auxito
Slight Vibrate at Idle
Old Sep 10, 2020 | 01:10 PM
F150SP's Avatar
F150SP
What causes a slight shake during idle?
I noticed an ever slight vibration at idle when stopped at the lights today. It idles at 550 rpm in drive and at 700 rpm in park.
I changed the idle air control valve just a couple days ago. It did this idle vibe prior to the IAC valve change..
Anyone know what gives ?
Old Sep 10, 2020 | 01:12 PM
ford390gashog's Avatar
ford390gashog
Low grade misfires, normally associated with spark plugs that are overdue.
Old Sep 10, 2020 | 02:40 PM
F150SP's Avatar
F150SP
Changed them 2 1/2 yrs ago. There isn't more than 10 000 miles on them.
Maybe the carbon that was cleaned from the throttle body a couple months ago, mucked them up ??
Black crud was emitted from the exhaust during the cleaning....
Cats were somewhat clogged too !
Changed those to brand new Magnaflow's.
Old Sep 10, 2020 | 08:12 PM
Lime1GT's Avatar
Lime1GT
I don't think you'll get a perfect smooth idle. Engine are run very lean at idle for emissions. You could always try a KAM reset and see if the computer re-calibrating will help.
kupiec20
13
Jan 4, 2009 06:01 AM
wildbyon
18
Mar 23, 2007 10:05 PM
snsgraham
Modular V10 (6.8l)
Jul 5, 2006 02:41 PM
fire232
Sep 16, 2003 08:44 PM
