Ford van rich condition
Old Jan 30, 2022 | 06:06 AM
Chance Piccin's Avatar
Chance Piccin
Eh. Replaced the dpfe It got a little better but still crazy rich. I clipped of the vac line to the egr and it started to go lean. I pulled a vacuum on the egr it’s self to rule it out. Leaving it to be the cheapest thing I purchased, the damn egr control solenoid. Runs and drives great. If I didn’t tell you it was that high of mileage you would never guess it has 500xxx on it, maybe 300xxx. Changing the transmission filter and outer wheel Bearings today. Then I’m going to leave it be for a while. That’s the way plan anyway
Old Feb 1, 2022 | 10:04 AM
Mike1's Avatar
Mike1
I'm trying to follow this thread but then it was hi-jacked and now I can't tell who's answering who for what. Anything someone can do to separate this thread?
Old Feb 2, 2022 | 04:35 AM
JWA's Avatar
JWA
The hijack or derailment begins at Post #8 so if you're able to weed that member's posts out you should be okay. Its rather rude and selfish IMHO---having made a separate thread would have been better for the OP.
Old Mar 2, 2022 | 08:20 PM
Chance Piccin
A weak fuel pump can cause those exact symptoms. I know it sounds backwards but when the fuel pressure goes up the volume of fuel decreases, intern the injectors open duration is longer Mekong it to where the fuel injectors never really close. It will run fine till it doesn’t.
Car Guy
Aerostar
Aug 1, 2015 06:04 AM
14psd
3.8 & 4.2L V6
Mar 24, 2007 07:40 AM
LL06282
Jun 15, 2006 11:03 AM
napaneeont
Aerostar
Oct 13, 2004 06:35 PM
