Hello all. The ABS light is on steady and the 4WD light flashes. There are times when I press the brake pedal and everything feels as it should. But, there are other times when I press the brake pedal and it feels like the ABS system has engaged. This can happen at any speed. Rolling up to a stop sign at 5 KM/h for example. In addition, when this happens I can hear a faint ticking sound that appears to be coming from the dash / front console.
Your time and assistance will be greatly appreciated. Peter
Check for a broken ABS tone ring on one of the front axle shafts. Really common failure on these critters.
Thank you for the prompt reply. Much appreciated. I should have mentioned this in my original post. The truck was in the shop last week to have the exhaust flex pipe replaced. I had the mechanic check out the tone rings. They appear to be fine.
