Fun with headlight locking ring
I kinda remember that the headlight locking ring may have lost one of the teeth on it, somewhere along the 520K miles it held in there, and perhaps was not holding the bulb connector in there just exactly perfect any more.
But last time I had to change the passenger side bulb (the more fun side, requires removing the primary battery first), I got it to hold OK enough to not be jiggling the bulb around, put the battery back in and proceeded to drive many more thousands of miles, cuz that’s what Super Duty does.
But some of those miles were pretty regularly not on brand newly paved roads and somewhere along the way that connector got loose enough to fray some wires and start shorting things out. Which burned up pert near 100% of that locking ring, the part of the housing it is supposed to connect to, and probably enough of the wires to the connector that I will have to splice in new ones. Happy happy joy joy.
The moral of the story is - if you have the primary battery out for any reason, you might could check that headlight housing connector ring to make sure it is still holding on tight, with it’s now 17-21 year old plastic teeth, all 3 of the tiny little buggers, and a simple twist back into their assigned places might keep this from happening to you. Over on the driver side, you only need to pop the hood to check out the health and wellness of that ring.
Soooooooo much better light than the bathroom glass lenses and they look good too. A little over $100/pair with clear turn signals.
For even better light, get a relay harness and 100/80 watt HELLA bulbs. This is literally night and day diffemce from your (dangerous) old foggy lenses and do not annoy other the drivers the way most drop-in HID/LED bulbs do.
on edit: before pic
I am in the market (while still dragging my feet) for new headlights and turn signal assemblies.
I want no amber to be part of the assemblies as i plan to simply install amber bulbs for the signal bulbs.
Provide websites and part numbers please.
There are some on ebay that are appealing to me.
I looked around for EagleEye some but am concerned on 2 things - the website is from Taiwan - and would "02-04" really match my build, which is from 11-99 = 2000 model year? If only source is via eBay...I can't afford a boo-boo on things like this, this week. Leaving for a long roadtrip pretty soon.
Off to search this site for any good after-market brand available a little more guaranteed from Zone/Vance/Reilly
I searched around for "EagleEye" some and concerned on 2 things - the website is from Taiwan, and would "02-04" really match my build of truck, which is 11/99 = 2000 model year?
Every time I have ever had a parts clerk look up a headlight part # they always ask me - old style or new?
I can't afford a wrong part off eBay right now - I am leaving for a long road trip very soon. Hope to find some suggestions elsewhere on this site for an aftermarket brand available from Zone/Vance/Reilley. Initial consult with them yesterday was "yeah, we can order that"
Both gpld trucks above started out with lenses like you have now. The x-cab is an E99 and the CCSB is a 2000.
If not, they can get this style (‘02-04) and possibly cover them with a lifetime warranty?
Please don’t get the bathroom glass style again. They REALLY suck.
Also, throw away whatever bulbs come with the new housings. I STRONGLY recommend a headlight relay harness from www.rallylights.com and 100/80watt HELLA bulbs. You’ll want to thank me many times in the future for this. If you must use store bought bulbs, spend the ludicrous $$ on the high end Silverstar bulbs (they are 1/2 the price of relay harness and the HELLA bulbs are <$10/pair).
just looking for a simple plug&play unit to use with the existing connector - shouldn't be that rocket science? my To Do list is long right now, not looking to do a total do-over with 3 different parts orders, though I am sure that would turn out nice. getting anything delivered lately in Corona Year is a crap-shoot with parts back-orders and delivery services swamped and a short work week this week, too. all that is magnified when you live out in the sticks.
The relay harness is plug and play using factory plugs - at least one of yours is broken, making this an even better idea. You’ll just attach a positive and negative wire to the battery (or a better place I’ll glady recommend for the cleanest instal)
The newer headlights I’ve suggested are 100% drop in. No different than the ****ty design of the faded junk you have now.
Good luck and keep us posted.
Should take about 30secs total to extract the headlight lens with an electric drill/impact.
I will mention that the driver side parking lamp assembly had a bad seal on top that allowed water to get into the housing. I just wanted to be done with the project so I sealed it with caulk as best I could rather than sending it back. I don't have any condensation in there at the moment, but time will tell if it needs to be replaced.
TYC 20644000 (20-6440-00) Headlamp Assembly $ 28.79
TYC 20643900 (20-6439-00) Headlamp Assembly $ 28.79
TYC 12506791 (12-5067-91) Parking / Turn Signal Lamp Assembly $ 9.51
TYC 12506891 (12-5068-91) Parking / Turn Signal Lamp Assembly $ 10.94
If not doing a relay harness and higher wattage bulbs, spend the $$ on ‘ultra premium’, etc bulbs.
Halogen bulbs will fade over time. Fresh bulbs put out more light in case someone said ‘these are still working, good!’ and reused their old bulbs.
