Track Bar Passenger side Bracket
Old Sep 26, 2020 | 12:03 PM
F350 1990's Avatar
F350 1990
OP -- I'm concerned about all that heat going in there.
What welding process are you going to use on installation? Also be mindful cleaning products like common degreasers leave a lot of residual and will affect the integrity of your welds.
Old Sep 26, 2020 | 03:40 PM
Yahiko's Avatar
Yahiko
I agree. Even if using Simple Green Precision Cleaner You will still need to give it a last surface treatment to remove what may be left behind on the surface.
This stuff is a lot stronger than the green stuff from Simple Green and does not cause hydrogen embrittlement.
https://simplegreen.com/industrial/p...ner/?locale=en
Old Sep 28, 2020 | 09:23 AM
extremefisherman's Avatar
extremefisherman
Trailering
Thanks F350 1990 and Yahiko,
I plan on tacking a 1/4 bar on the backside of the perch mount to attempt to keep it straight in case I dump too much heat into it. But I plan on taking my time and not rooting in one pass once the bracket has been welded back together. I do plan on at least a plate reinforcement along the separation area. I do not have a procedure picked out but will either be MIG or stick.
MIG... ER70S-6 wire .030
Stick... DCEP 6010 or AC 6011.
Seems about right. But certainly open to feedback.
User 71024
23
Dec 1, 2020 07:21 AM
Jayv10
Apr 30, 2020 09:53 PM
frisbeeguy
Jan 31, 2015 05:56 AM
drewthestu
Jun 9, 2014 08:24 AM
