Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
INFO NEEDED
Old Sep 2, 2020 | 05:06 PM
Shaggster's Avatar
Shaggster
INFO NEEDED
Hey guys
Need some assistance. I'm thinking of buying this truck. This would be the first time owning a truck. Does anyone know what year and model this truck is or how I would find it?
You dont really get a lot of these here in South Africa, hence I'm pretty clueless.
Any info would be awesome.
Old Sep 2, 2020 | 06:19 PM
seville009's Avatar
seville009
if you (or someone) have access to it, maybe look at the info on the driver’s door pillar sticker.
get the vin too, of course, and see what comes up on a search
Old Sep 6, 2020 | 03:03 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Welcome to FTE. That is what is commonly referred to as a "bump side" truck. Due to the bumped OUT line down the side of the truck. If you can get the dvrs side door open look for a aluminium tag riveted to the edge of the door. That will have the vin, you can decode here. https://www.fordification.com/tech/vin_find.htm
It is a 5th generation F100, 1/2 ton (5 lug), and could be a 1967 thru 1972. https://en.wikipedia.org/wiki/Ford_F...fth_generation)
Looking at the grill I bet its is a 71 or 72, the thread you want to ask and get all sorts of help is here. https://www.ford-trucks.com/forums/forum39/
Old Sep 6, 2020 | 03:23 AM
Shaggster's Avatar
Shaggster
Wow, this is much appreciated.
Old Sep 6, 2020 | 03:29 AM
77&79F250's Avatar
77&79F250
No problem, now since that is a right hand drive truck, that aluminium plate (it is actually called a "Warrant plate") and NOT a VIN plate. It could be riveted on the "other door" and then yes there should be a white sticker called a "Safety Certification" on the B pillar by the door striker. And it should have the matching vi# also.
sarinabieber
Aug 1, 2019 05:11 PM
Curated Content Editor
General Automotive Discussion
Mar 29, 2017 04:50 PM
runawayhound
Jan 13, 2016 04:15 PM
doubledoyle
21
Apr 22, 2008 01:36 PM
36fordhotrodtruck
1947 and Older Ford Trucks
Aug 21, 2007 03:47 PM
