Sponsored by: Real Truck
replacement mirrors
Old Sep 1, 2020 | 04:12 PM
tjfarmer's Avatar
tjfarmer
replacement mirrors
Hello, I have a '99 super duty with a broken mirror on the right side. It is the larger "two arm" design. It is a power mirror, but not extendable. It has the blind spot portion on the bottom. It is not heated, and does not have turn signals. I've heard there would be a benefit to upgrading to a newer style mirror?? If so, what should I look for that will still fit and function (maybe a little better than the originals)?
Thanks.
Old Sep 1, 2020 | 04:50 PM
Colorado350's Avatar
Colorado350
Welcome to the Forum.
Here’s a picture of the difference of the original mirrors and the replacement (top)mirrors. The blind spot mirrors alone are worth the money! My original mirrors had power, the new ones are power, heated with turn signals. I’m in the process of wiring the turn signals probably won’t worry about heat...
A1 auto is a sponsor here, I bought mine off EBay. You may need to trim the insulation on the mounting portion and there was a plastic pin I’ll call it that needed to be removed both very easy to do. But worth the money.
troverman
Nov 1, 2016 06:14 AM
someday
May 24, 2016 03:05 PM
96f150
1997 - 2003 F150
Dec 16, 2010 07:30 AM
nosubt2
Jan 11, 2007 10:34 AM
