Crankshaft Position Sensor location
Old Sep 1, 2020 | 11:10 AM
PNGento's Avatar
PNGento
Can someone tell me where to find the CPS on my 2017 Super Duty diesel? I've seen some say under the compressor in the serpentine belt area...and also have heard it is in the transmission housing area. Can someone confirm? Thanks in advance.
Old Sep 1, 2020 | 02:55 PM
jollyrogr's Avatar
jollyrogr
which engine? Apparently I missed where you said diesel.
On the 6.7, the CKP is in the bellhousing on left side of the engine. It's underneath a round cover.
Service manual also says:
NOTICE: Do not use magnetic screwdrivers or other magnetic tools around the CKP sensor and the crankshaft sensor pulse
ring or damage to the components may occur.
Old Sep 1, 2020 | 03:05 PM
ford390gashog's Avatar
ford390gashog
The CPS is hidden behind the fan. You have to remove radiator, fan, etc to get to it.
Old Sep 2, 2020 | 10:07 PM
PNGento's Avatar
PNGento
Hmm...so, this verifies only what I was worried about. One response says in the tranny bell housing area, and the other behind the fan around the serpentine belt. So, basically back to square one. Just to reiterate, this is a 2017 F350 dually diesel., so 6.7L engine.
Old Sep 2, 2020 | 11:48 PM
jollyrogr's Avatar
jollyrogr
I think gashog was thinking of the camshaft position sensor (CMP). For that one the service manual says to remove the cooling fan.
The crankshaft position sensor (CKP) is definitely inside the bell housing.
Old Sep 3, 2020 | 06:39 AM
PNGento's Avatar
PNGento
Thanks muches. I'll go searching for it when the sun comes up.
Old Sep 3, 2020 | 09:03 AM
neomac3444's Avatar
neomac3444
Hope this helps
Old Sep 3, 2020 | 09:33 PM
PNGento's Avatar
PNGento
Perfect...thanks.
remhaust
Mar 24, 2011 06:16 PM
WAHNISHIN
1997 - 2003 F150
Oct 20, 2007 09:13 AM
weekendwarriorfsw32
May 18, 2007 02:55 PM
xxxpheonix
Modular V10 (6.8l)
Nov 16, 2006 10:46 PM
Raul Ortega
Oct 3, 2006 06:42 PM
