Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1973 LN600 Radiator
Old Sep 1, 2020 | 08:17 AM
texczech's Avatar
texczech
1973 LN600 Radiator
I need to replace the radiator in this 73 F600, (edit: LN600) it has a V8 Gas motor and the VIN isN60EV055254--- It is a downflow radiator, cap on one side, off set outlets, the odd thing about this one is there is a metal bracket on the top middle that has about an 1 1/2 hole in it for a stabilizer bar that runs back to the firewall. Thanks
Old Sep 1, 2020 | 03:03 PM
85e150's Avatar
85e150
N60 would be an LN600, not an F600.
Engine code E = FT series 361 2v.
Which one matches your truck?
https://cimg3.ibsrv.net/gimg/www.for...7d9b6f01c6.jpg
Old Sep 1, 2020 | 03:15 PM
85e150's Avatar
85e150
Have you had it looked at to see if it can be rodded out, cleaned up, resealed?
Outfits like this have radiators. You may need to match one up from a slightly different model.
https://www.vanderhaags.com/Search-R...ytype=radiator
Old Sep 1, 2020 | 03:42 PM
texczech's Avatar
texczech
It is the LN type of vehicle
Old Sep 10, 2020 | 02:50 PM
Destroked 450's Avatar
Destroked 450
Nothing odd about that hole, all L models have that setup, even the diesel models, with flip up hood and no core support that bar keeps the radiator from flopping back and forth.
The L800 gas models I've worked with had cross flow radiators, we should have on from a 82 429 truck in the shop, swapped the cab and hood onto a diesel chassis.
trevorrules
17
Mar 20, 2021 08:25 PM
Red Rascal
May 16, 2018 02:13 PM
jeff14346
Aug 27, 2011 04:09 PM
