Sponsored by: Real Truck
Bad unit bearings?
Old Aug 31, 2020 | 09:57 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Bad unit bearings?
So.....I now have my front tires cupping on both outer edges and shaking in my steering wheel. My timken unit bearings were installed in 2018 BUT I only have less than 6,000 miles on the truck since then. I pulled the front brakes and found grease coming out of both seals on the bearings! Called Timken no response, then emailed twice and they did respond but told me warranty is only 1year from date of purchase.
Old Aug 31, 2020 | 10:00 AM
SuperDutyScaler
Old Aug 31, 2020 | 10:47 AM
BigBlue99's Avatar
BigBlue99
how much play is in the bearing? When the tire is mounted, but off of the ground, can you notice any movement if you rock the tire?
Point being that maybe the bearings are not bad. Grease you see coming out is just the excess pushing through the seals.
Old Aug 31, 2020 | 12:00 PM
Just Strokin's Avatar
Just Strokin
Cupping often indicates tires out of balance condition. Also could indicate bad shocks.
Old Aug 31, 2020 | 09:55 PM
Djosbun's Avatar
Djosbun
High levels.of vibration will cause premature bearing failure. If the grease is black (not due to dirt), the vibration caused a severe increase in friction, which overheated the bearing. When the grease looks like tar, that's the tell-tale sign of lithium complex grease that's gone over-temp.
(I work for a bearing manufacturer)
-- Dave
Old Sep 2, 2020 | 12:20 PM
SuperDutyScaler
NO IVE CHECKED THREE TIMES AND CAN NOT FIND ANY PLAY. WHAT I DO FIND IS I CAN FEEL A CLUNK WHEN THE TRUCK IS ON THE GROUND AND I HAVE SOMEONE TURN THE WHEEL
SEALS SHOULD NOT LET THE GREASE PASS
TIRES WERE JUST MOUNTED AT THE BEGINNING OF THE SUMMER ON THE NEW PRO COMP CLASSICS, SHOCKS ARE BRAND NEW AT TIME OF WHEEL CHANGE
-- Dave
GREASE ISNT BLACK MORE DIRTY LOOKING FROM BEING THERE COLLECTING ROAD DEBRIS
Old Sep 2, 2020 | 12:53 PM
BigBlue99's Avatar
BigBlue99
Clunk when turning sounds like a bad tie-rod end on a steering linkage. could explain the vibration and cupping too in my opinion if the tires are toe'd in more when driving.
Old Sep 2, 2020 | 10:02 PM
SuperDutyScaler
It's all brand new with under 1k miles
Old Sep 8, 2020 | 09:03 AM
BigBlue99's Avatar
BigBlue99
If there is no noticeable play in the unit bearings then i would concentrate on where that clunk is coming from. if not tie-rod ends then maybe ball joints or the rubber bushings for the leaf springs and hangers. i have had to replaced those before as well.
Old Sep 13, 2020 | 10:11 PM
SuperDutyScaler
Wheels, shocks, steering box, tie rod, drag link, leaf springs, track bar, pitman arm, ujoint, all brand new
g8trowwd
1997 - 2003 F150
Aug 24, 2013 11:26 AM
garydmundy
Jun 27, 2013 10:49 PM
motor-man
Dec 19, 2012 05:25 PM
OrcusOmega
Apr 4, 2007 10:47 PM
tomrooster-1
General Automotive Discussion
Jan 19, 2006 09:02 AM
