239 Fuel Pump Drive
Old Aug 30, 2020 | 07:33 PM
arthall's Avatar
arthall
239 Fuel Pump Drive
I believe that the fuel pump push rod is driven off of the rear of the cam shaft. How many strokes does the push rod make for every revolution of the camshaft? How is the push rod retained? Can it be lifted out when the fuel pump and the mounting adapter are removed? Is the push rod located by a bushing in the block?
Old Aug 30, 2020 | 07:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The pushrod runs on an eccentric on the camshaft, it makes one cycle for each revolution of the camshaft. Lift is only 0.200". It runs fairly loosely thru a bushing in the oil gallery. You can remove the pushrod if you pull the fuel pump stand off (make sure you keep track of which end rides on the cam). The pushrod just lifts out, no retainer.
Old Aug 30, 2020 | 07:54 PM
Mixer man's Avatar
Mixer man
The cam has a single eccentric lobe on the end, so one full stroke per cam revolution, BUT the pump operates on the upstroke AND the downstroke. Since the cam runs at half engine speed, this in effect gives a complete pump throughput cycle per engine revolution.
Retained by bore in block casting, no bushing iirc, lifts right out after interferences are removed.
Old Aug 31, 2020 | 09:49 AM
arthall's Avatar
arthall
Thanks for the education!
anthony f47
Jun 28, 2016 04:25 PM
49m47
Apr 27, 2014 01:14 PM
dlb.motorman
May 10, 2013 06:15 PM
howdy71475
1947 and Older Ford Trucks
Mar 2, 2007 10:16 PM
John - NNY
Jun 30, 2006 06:45 PM
