No spark
Old Aug 30, 2020 | 06:41 PM
galeb124's Avatar
galeb124
No spark
I've got a 79 f100 there no spark new distributor new coil new wires new plugs where do I look next
thanks
Old Aug 30, 2020 | 07:59 PM
v84960's Avatar
v84960
Look at the service manual. Stop throwing parts at it and get the instructions to troubleshoot it properly. Someone else here can probably point you in the right direction to get an online copy of the manual you need.
Old Aug 30, 2020 | 08:41 PM
Alex from GA's Avatar
Alex from GA
Do you have 12v @ the + side of the coil when the key is on? Is the resistor wire(pink) open? Did you set the points? Are the points shorted somewhere? Change the condenser to a Ford product.
Old Aug 31, 2020 | 01:44 AM
Jerry Merrill's Avatar
Jerry Merrill
Isn't this model a Duraspark ignition, check the ignition module box.
Old Aug 31, 2020 | 02:13 AM
Christmas's Avatar
Christmas
What is this new distributor? Things like this are usually installer error. Verify 12v at the positive on the coil. What most folks don't realize is power does not flow through the distributor, it is only a trigger to ground. That's why matching a coils resistance is important to not burn things up.
Old Aug 31, 2020 | 04:26 PM
Alex from GA
Jerry is right, I read fast and thought it was a '70.
78fourby4f250
Jun 21, 2015 02:31 PM
FatherDonald74
1978 - 1996 Big Bronco
Jun 9, 2014 08:35 PM
luvcycles 2
Modular V10 (6.8l)
Jun 4, 2010 09:19 PM
48' fordster
Flathead V8 & Flathead 6
15
Apr 23, 2007 06:33 AM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
