Sponsored by: Real Truck
Manufacturers Declared Weight
Old Aug 30, 2020 | 04:42 PM
cmpts_cmp's Avatar
cmpts_cmp
Hey all
Is there a site to get details of the original declared weight for my 2008 f250?
I'm after the curb weight and GVWR. I have the original brochure but there's nothing with either of those weights on.
TIA
Old Aug 30, 2020 | 06:48 PM
seville009's Avatar
seville009
should be a sticker on your driver’s side door pillar with weight info for that specific truck
Old Aug 30, 2020 | 07:53 PM
RV_Tech's Avatar
RV_Tech
Best way to get actual curb weight is to run your truck across a CAT scale.
Old Aug 30, 2020 | 08:23 PM
senix's Avatar
senix
fleet ford.com can get you a lot of the info based upon your particular set up.
Look at the towing guide for your year, model and size, cab and motor and gears.
surprised that you don't have the yellow sticker on the door.
Old Aug 31, 2020 | 02:58 AM
cmpts_cmp's Avatar
cmpts_cmp
got it, here: https://www.fleet.ford.com/content/d...VTTowGuide.pdf
So, am I looking at the GVWR on Page 6 and that's the truck weight, and not the RV/trailer/payload?
Old Aug 31, 2020 | 05:11 AM
senix's Avatar
senix
Starting on page 18 as well. That will tell you your max 5th wheel and bumper plus the GCWVR. All these numbers are important.
What are the particulars of your truck.
6.4, F250.
What gears, do you have the snow plow or camper package?
attached is an empty weight ticket of my 2008
Old Aug 31, 2020 | 05:34 AM
cmpts_cmp's Avatar
cmpts_cmp
6.4, F250.
Hey
So, the truck is Ford F250 2008 XLT 5.4l v8, 6 ft bed, 5 gears, tow package.
Old Aug 31, 2020 | 05:35 AM
senix's Avatar
senix
Do you have the white sticker on the door?
Old Aug 31, 2020 | 05:37 AM
cmpts_cmp's Avatar
cmpts_cmp
yes, but the weight has been deleted as it was an import to the UK. So, the new plate is a downrated plate. I want it to be put back to the original hence the query
Old Aug 31, 2020 | 05:58 AM
senix's Avatar
senix
take a pic of that sticker, I will do some research.
Old Aug 31, 2020 | 06:04 AM
cmpts_cmp's Avatar
cmpts_cmp
legend. Thanks
Will DM you
Old Aug 31, 2020 | 06:06 AM
cmpts_cmp's Avatar
cmpts_cmp
in fact, i can't DM you. Permission issue. Can you send me one and ill reply. Thanks
Old Aug 31, 2020 | 07:21 AM
cmpts_cmp's Avatar
cmpts_cmp
can't reply to your PM so here's the tag... if you need the VIN I'll have to send another way
Old Aug 31, 2020 | 10:14 AM
senix's Avatar
senix
So your gears are 3.73 limited slip.
GCVWR is 16K.
Page 6 according to your wheel base and 4x4 or 4x2 will show the GVW and payload.
Best you can do is to weigh it just like I did and take that GVW and subtract the actual weight to determine accurate numbers
Old Aug 31, 2020 | 11:28 AM
cmpts_cmp's Avatar
cmpts_cmp
GCVWR is 16K.
legend. Thanks for that
And i need full tanks, etc for the CAT?
