Sponsored by: Real Truck
Manufacturers Declared Weight
Old Aug 31, 2020 | 11:32 AM
senix's Avatar
senix
I would use a full tank and whatever you normally carry. That should then help.
Also something to consider, as long as you don't exceed the front and rear axle ratings and the tire ratings (on the sidewall) you can carry up to that amount per DOT.
Old Aug 31, 2020 | 11:33 AM
cmpts_cmp's Avatar
cmpts_cmp
awesome. Will do. Cheers
Old Sep 2, 2020 | 01:47 PM
cmpts_cmp's Avatar
cmpts_cmp
The CAT today said 3340kg (full tank of fuel, oils, screenwashs etc)
Old Sep 2, 2020 | 01:48 PM
senix's Avatar
senix
give you the numbers for steer and drive axle?
Old Sep 2, 2020 | 01:54 PM
cmpts_cmp's Avatar
cmpts_cmp
Front - 1760 kg
Rear - 1540 kg
They said their total are slightly out with the vehicle kerb/curb weight as the scales are sloped.
Old Sep 2, 2020 | 02:22 PM
senix's Avatar
senix
Front 3880 lbs
Rear - 3395 lbs
Total: 7363 lbs.
doing the math is 7275 (discrepant) from the original total of above.
houlis
Dec 13, 2020 12:02 PM
usmcar15
All Things Towing
Sep 11, 2011 07:26 AM
seth1
1983 - 2012 Ranger & B-Series
Jul 16, 2005 10:16 PM
scrape
Apr 12, 2005 05:23 PM
