almost went too far
Old Aug 31, 2020 | 08:27 AM
helifixer's Avatar
helifixer
Originally Posted by Pugga
your regens at 45%? Mine won’t start regen until the DPF status reads 99%, then it starts regen and dropping down.
I was at 500 miles since the last regen.
Old Sep 1, 2020 | 07:06 PM
System's Avatar
System
Prolocutor
Bart, there is a lot of safety factor in there. On my last two trucks, I've run at 0 MTE for quite some time in harry situations. I've found when I hit 0 to empty, I had about 3-5 gallons left in the tank based on what I saw when I filled up...
Old Sep 1, 2020 | 07:53 PM
dirthawg's Avatar
dirthawg
Are you saying the tank capacity Ford lists actually will hold more than that number? And if so then maybe the DTE is set for the listed capacity rather than the total capacity so that would create a reserve?
Old Sep 1, 2020 | 08:45 PM
System's Avatar
System
Prolocutor
No, I'm saying the opposite. DTE is conservative and when it says 0 to empty, there are a few gallons left. There is actually a way to reprogram the DTE using engineering mode in your instrument cluster. You do hand calcs and do the math to reprogram and get it more accurate. It also gets your average MPG more accurate. There are youtube videos on it.
Firefighter 1406
Oct 4, 2019 11:19 AM
Monster-4
Dec 22, 2017 07:20 AM
3golfjack
Sep 4, 2017 04:18 AM
indebt
Jan 14, 2011 09:34 PM
John7894
17
Aug 30, 2008 11:47 PM
