Unladen Axle Weight; Tire PSI
Brand spankin’ new 2020 F-350 diesel, SRW, Crewcab, 6’9” bed. Dealer had tires at the max of course at 80psi. I know this truck isn’t going to ride like my previous F-150...
Looks like my curb weight is ~7,500 lbs. Does anyone have the approximate weight on each axle (SRW, Shortbed, Crew, Diesel)?
And does anyone know an approximate minimum tire psi when not hauling or towing (Michelin LTX A/T2 LT275/65R20)? I’ve seen the load charts but I’m looking to get down to minimum safe and good wear psi for front and back? I’ll inflate to max when pulling my fifth wheel, but for daily driving that’s way too much...
Thanks!
Thanks!
Thanks!
Thanks!
I am trying out 50/55 with the same tires, be warned you will need to adjust the TPMS in forscan. The changes will also show in the Fordpass app.
Very similar truck as you (2020 F350 SRW crew cab short bed Lariat 6.7 powerstroke 4x4 FX4 with 18" wheels). Truck weighs 8160 pounds.
Dealer had the pressure at 60 psi on the front and 80 on the rear like Ford recommends and I left it there since I tow and I didn't want to monkey around airing up the tires all the time. I think the truck rides fine at those pressures. Much better than the 2500 Chevy it replaced.
I'd google your tire model's load & inflation tables. That will tell you what to air to. I round up to the nearest 5 psi to ensure I'm always covered no matter the load I'm at. I'd also take your truck to a scale and weigh the axle. My gasser was 7440# with me in it. I'm betting your diesel is more like 8k. I run 50f/40r on 35x12.5 ridge graps and tire wear looks good so far. I found most of this out when I towed and the trailer felt loose behind me. Rear tires were at 65 psi. I pulled into an empty lot and noticed the dust on the contact patch was only half the width of the tire. Way overinflated. I aired down to the recommended 50 psi for my load and it tows perfect now. Those tables show you what's safe and what's better for your tread life.
Thanks everyone, hopefully I have this figured out now. I’ll weigh each axle after I get my hitch installed (and with a full tank of fuel).
Michelin’s table (https://www.michelintruck.com/refere...tion-tables/#/), assuming their shown weights are for the axle, for my Michelin LTX A/T2 LT275/65R20, I get:
4,160lbs @ 35psi
4,560lbs @ 40psi
4,950lbs @ 45psi
5,360lbs @ 50psi
5,700lbs @ 55psi
6,060lbs @ 60psi
6,390lbs @ 65psi
6,750lbs @ 70psi
7,080lbs @ 75psi
7,500lbs @ 80psi
Until I weigh, I’ll go with an estimated 4,800lb front, 3,500lb rear, So 45psi front and 38psi rear. Is this the way to do it?
And how hard is it to reprogram in FORScan? I’ve never done that before...
4,160lbs @ 35psi
4,560lbs @ 40psi
4,950lbs @ 45psi
5,360lbs @ 50psi
5,700lbs @ 55psi
6,060lbs @ 60psi
6,390lbs @ 65psi
6,750lbs @ 70psi
7,080lbs @ 75psi
7,500lbs @ 80psi
