Lube Ignition Switch?
Old Aug 26, 2020 | 04:01 PM
tinnerjohn's Avatar
tinnerjohn
The ignition switch in my 66 P-100 feels stiff and dry. Any recommendations on lubing it. I'd prefer to not take it apart if I don't have to, thinking of a shot of WD-40, I've used that on push-pull switches with success, but I thought I'd ask the guru's. Thanks. John
Old Aug 26, 2020 | 04:21 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Powdered graphite does not collect dust and dirt that would just make it worse. You can get it from local auto parts, or amazon of course.
Old Aug 26, 2020 | 05:03 PM
john jamieson's Avatar
john jamieson
It can also be found at hardware stores in their locks and keys area. They sometimes have it in an aerosol that quickly evaporates.
Old Aug 26, 2020 | 05:20 PM
Danno5's Avatar
Danno5
FWIW, I just got a new ignition switch from Dennis Carpenter - the instructions recommended a shot of WD-40 to lube it up (for the door locks also).
Old Aug 26, 2020 | 05:44 PM
resonateur's Avatar
resonateur
My favorite "light" lube that creeps into every crevice is still Tri-flow. It comes in a spray and a small bottle with a long thin tube that you can insert into key slots like the door locks and ignition. It only takes a couple drops, so a bottle will last a long time. WD-40 is very short lived and not really a good lubricant. WD stands for "water displacement".
Old Aug 26, 2020 | 06:11 PM
tinnerjohn's Avatar
tinnerjohn
I didn't think of the graphite. About the only thing I've found WD-40 good for is lubing window run channels. I think what it did on the switch for my Farmall Cub was flush some crud out, making it smoother.
Old Aug 27, 2020 | 04:20 AM
Crop Duster's Avatar
Crop Duster
This stuff works well dries clean and slick. You should pull the lock cylinder and clean it first and put a dab of white grease on the end of it. All you need to pull the lock cylinder is a paper clip. Turn it to acc. stick the pin in the hole, turn it counter clockwise and pull it out.
Old Aug 27, 2020 | 03:05 PM
djtaylor's Avatar
djtaylor
A lock smith I know says the only lube he uses is Tri-Flow.
Old Aug 27, 2020 | 07:49 PM
resonateur's Avatar
resonateur
...interesting... I have been using it for years. I use the spray in the house on closet door and drawer glides and it lasts a long time....
Guntherexpress
Mar 28, 2017 03:39 PM
chrissmallwood
Large Truck
Nov 27, 2016 07:17 PM
69crewcab
Mar 1, 2002 06:50 PM
