Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Possible ignition switch issues
Old Nov 25, 2016 | 04:36 PM
chrissmallwood's Avatar
chrissmallwood
Hi all. I think I'm going to have to put a new ignition switch in my truck. Earlier today I drove to the store and when I left the truck died before I made it out of the lot. It would restart each time then die after I would take off. I noticed that before it would die that I would lose all the gauges and I saw that when the gauges quit working and it started to die if I wiggled the key then everything would come back on and it would keep running. Would you guys recommend trying to find an nos ignition switch or is there a specific type you would recommend.
Old Nov 25, 2016 | 06:36 PM
85e150's Avatar
85e150
Is this for your '85 F250?
Old Nov 25, 2016 | 07:46 PM
chrissmallwood
No, its a 67 F600
Old Nov 25, 2016 | 10:58 PM
85e150's Avatar
85e150
NAPA sells ignition cylinders, maybe the whole switch. It is probably that the ignition switch if common to several models over several years of production.
You could pull the switch and see if you can get a match.
We may get some better responses, such as Numberdummy giving us the rundown on the part number etc.
Old Nov 26, 2016 | 08:40 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I took a really quick look, and a 1967 F250 ignition switch is actually available from of all places, Autozone (which means many other parts places will have it too).
Duralast Ignition Switch LS492- ReadReviews onDuralast #LS492
I'm not sure it's exactly the same thing you have in an F600, but I remember my brother's 1968 F600 had a lot of similar parts to my 1974 highboy. I'm willing to bet the ignition switch was the same too.
Old Nov 26, 2016 | 09:17 AM
chrissmallwood
My main question is should I try to find an original or go aftermarket? I don't want to buy one from the parts store if it won't last as long as OE would
Old Nov 26, 2016 | 06:31 PM
Tenwheeler's Avatar
Tenwheeler
Napa is usually good on switches.
Old Nov 27, 2016 | 09:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5AZ-11572-B .. Ignition Switch (Motorcraft SW-417) / Available from Ford.
MSRP: $19.56 / autonationfordwhitebearlake.com price: $11.84 + shipping charges from MN
1967 F100/750 // 1965/67 Galaxie/LTD/Thunderbird / 1966/67 Falcon/Fairlane/Comet / 1967 Mustang/Cougar.
Old Nov 27, 2016 | 12:30 PM
krewat's Avatar
krewat
Motorcraft SW-417 $12.44 from Amazon
Old Nov 27, 2016 | 03:05 PM
chrissmallwood
Next question. I pulled the old switch out and theres a spade connection on the outside edge and there was nothing attached to it. Should there be something hooked there and if so what is it?
Old Nov 27, 2016 | 06:26 PM
krewat's Avatar
krewat
The only thing I can find is a reference to a brake warning light.
https://www.ford-trucks.com/forums/1...ing-light.html
Old Nov 27, 2016 | 07:15 PM
85e150's Avatar
85e150
I googled and found it labeled as "ground" in a couple places.
But look at the violet wire here, matches the brake light as mentioned above (picture 5):
http://classicbroncos.com/img/ignitionswitch5.jpg
Old Nov 27, 2016 | 07:17 PM
chrissmallwood
Sounds good. I don't have a brake warning light so no worries there.
brknight
Jan 2, 2011 09:13 PM
69crewcab
Mar 1, 2002 06:50 PM
