2003 7.3 looses acceleration
Old Aug 26, 2020 | 03:39 PM
Dwayne Brooks's Avatar
Dwayne Brooks
2003 7.3 superduty crew cab. while driving my engine suddenly goes back to idle then after a few seconds it will pick back up and go. Or at least it would, today i came to a complete stop, and engine would not rev up at all. After sitting for approximatly 30 mins i now have acceleration. i should also say I have put another accelerator pedal on it (used). My pedal is adjustable. is there anything else i should be looking at?
Old Aug 26, 2020 | 07:38 PM
pirschwagon's Avatar
pirschwagon
AP Wiring / Connectors
Old Aug 26, 2020 | 08:06 PM
jstihl's Avatar
jstihl
Throttle position sensor or idle validation switch gone bad maybe? Not sure what came with the new pedal
Old Aug 26, 2020 | 09:03 PM
BWST's Avatar
BWST
Got Data?
There is a Key On Engine Running switch test (two tests below the one checked in the screenshot below) you can run on the Forscan app on your phone, and an OBDII dongle. It will help you verify your pedal assembly is working or not. Read your codes with this app as well to see if there are any related to this issue.
Your description does seem to point to an intermittent IVS on the pedal assembly. I think the IVS and accelerator pedal position sensor are one unit on the '02-'03 trucks.
Did this issue happen with both the original pedal assembly and this used one?
Old Aug 26, 2020 | 09:41 PM
Dwayne Brooks
the issue happend with both pedals
Old Aug 26, 2020 | 09:43 PM
Dwayne Brooks
it happens with both pedals
Old Aug 26, 2020 | 09:51 PM
Dwayne Brooks
Old Aug 31, 2020 | 03:40 PM
Dwayne Brooks
are the ivs and throttle position one unit on the 2003 7.3 with adjustable pedals
Old Sep 1, 2020 | 08:05 AM
Listor's Avatar
Listor
hmm how bout a short in the gear shift for the Overdrive? Should have blown a fuse, might be worth checking
Todd Dawson
Aug 27, 2019 08:15 PM
FSJ-EARL
18
Aug 5, 2008 05:42 PM
DD1684
Mar 13, 2006 04:20 PM
pksignator
Jul 22, 2005 01:32 PM
lifted ssx
Oct 19, 2003 08:11 AM
