Cooling question
Old Oct 22, 2003 | 11:42 AM
ctfuzzy's Avatar
ctfuzzy
Hi again Peter,
The reading you received from your ohm meter is probably right on the money. What you have to remember is that the resistance you measure will fluctuate (possibly a LOT) based on the temperature of the engine.
The resistance reading "Stone Cold" in Minnesnowta will be different then "Stone Cold" reading in Florida.! . . even in July.
I think more than the actual numbers, you are looking for a marked change in the reading between "cold" and "hot". If you see a change, chances are the sending unit is working properly.
It also sounds like you have indeed found the thermostat (Inside that flange with the 2 bolts).
Be patient and stick with this job. I have the feeling you are close to the solution . . or at least accurately identifying the problem !
HTH.
Originally posted by Peter94
ok, but why arent the ohms on the sending unit right? or was i just measuring it wrong? i took the positive wire from the multimeter, and put it on the top of the sending unit where the wire hooks on, then i grounded the black to the intake manifold. i think in the haynes it said to ground it to somthing on the engine. but i'll check the temp sensor. and from what i understand from the above post, the thermostat is inside the metal flange that the hose is clamped onto, and that is bolted onto the engine block with 2 bolts, does this sound right?
Old Oct 22, 2003 | 06:11 PM
Peter94's Avatar
Peter94
hey, thanks for all the help everyone. I put in a new thermostat and gasket, for like $6.11, fired her up, drove it to a nearby hill, put it to the wood, and the heat didnt even get up past o on normal, so its right where its supposed to be. so thanks again...
slinginsaws
Nov 11, 2014 07:10 AM
Blown 331
13
Mar 25, 2012 09:14 PM
Fordbronco69
Jun 7, 2010 09:53 AM
randallc
20
Apr 14, 2004 03:50 PM
