86 300 carb issue
Old May 11, 2015 | 03:11 PM
JayzDaddy's Avatar
JayzDaddy
86 300 carb issue
Had the carb tore down and cleaned about a month ago. Im not getting fast idle on cold start and it chugs and lopes down around 4-500rpm on cold start. I can smell it rich on cold start. Now if i keep rpm up after 20-30sec it idles and runs like new money.
Any ideas? Feedback stuff isnt working but itll be swapped soon.
Old May 11, 2015 | 03:47 PM
InfantryCPT's Avatar
InfantryCPT
Choke isn't set up right
Old May 11, 2015 | 03:49 PM
InfantryCPT
https://www.ford-trucks.com/forums/1...ent-101-a.html
Old May 11, 2015 | 06:03 PM
Franklin2's Avatar
Franklin2
Who tore it down? There is a lot of little things over in the choke area that can be put together wrong or left off.
Look at the choke door on top of the carb with the aircleaner off. The more the door is closed, the faster the idle. As it opens, the idle gets slower.
Old May 11, 2015 | 06:13 PM
JayzDaddy's Avatar
JayzDaddy
My cousin, he works in a race shop. I dont think the choke is setting. I adjusted it to slightly open on a cold start but it never fast idled after that one time. I dont think its closing when i prime it on cold start.
Old May 11, 2015 | 06:36 PM
Franklin2's Avatar
Franklin2
You need to go ahead and adjust it so it's shut. It should have a vacuum diaphragm with a arm that when the engine starts and builds vacuum, the arm will crack the choke open just a little bit so it will keep running.
Ferrariferg
Oct 16, 2011 11:37 AM
silver777
20
Oct 30, 2010 11:03 PM
Redneck1465
Feb 10, 2007 06:11 PM
nskitts
Nov 19, 2006 09:51 PM
ajstephan
1983 - 2012 Ranger & B-Series
Mar 4, 2001 08:48 PM
