Compression test
Old Aug 25, 2020 | 09:13 PM
RA52025's Avatar
RA52025
Banned
Compression test
Hello,
I have a 93 IDI and did a compression test and got most cyilnders 390 and one was 450 are these reading normal ?
Old Aug 26, 2020 | 11:49 AM
DarkOverCast's Avatar
DarkOverCast
Most say 350+ is desired so id say those are fine.
You can also compression test on a hot motor and the numbers will jump a bit, most of mine jumped roughly 80+- psi
Rings seat better when everything is all warmed up
Old Aug 27, 2020 | 10:06 AM
Olds64's Avatar
Olds64
x2
If you do the compression test on your engine after it's hot and remove all of the GPs your numbers will go up.
Old Sep 4, 2020 | 11:56 PM
RA52025's Avatar
RA52025
Banned
Awesome thats good to hear. What would cause excessive blow by ? It has one of those first gen banks turbo kit. And on the front of the pump houseing it has quite a bit of blow by coming out of the pipe
Old Sep 5, 2020 | 12:22 AM
DarkOverCast
Just the way the motor was designed
6.9/7.3idi, 7.3/6.0/6.4/6.7 powerstroke all have positive crankcase pressure by design.
It does get worse with age but generally shouldn't get excessive until you start loosing compression below the desired threshold.
If you take your oil cap off does it throw oil droplets out while idling? If not I'd say it's just fine.
Old Sep 5, 2020 | 08:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
i wonder if your CDR valve is bad? when the diaphragm ruptures it lets oil past.
Old Sep 5, 2020 | 04:52 PM
DarkOverCast
The cdr is normally in an open state, it's really just a runaway device incase the air filter is plugged. Weather it's intact or not it'll still pass oil into the intake
Old Sep 5, 2020 | 05:56 PM
tjc transport
i ain't rite
when the diaphragm in my 88 ruptures, it dumps a whole lot more oil into the intake.
Old Sep 5, 2020 | 06:43 PM
DarkOverCast
Interesting, when I replaced my cdr I noticed just as much oil getting to the intake.
Old Sep 5, 2020 | 07:12 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the Victor valley pan has some baffles that help cut down on some of the oil... other Pans don't have the baffles, just open hole for the CDR
Old Sep 5, 2020 | 10:33 PM
DarkOverCast
Mine had the baffles because they wanted you to poke holes in it when I did my first turbo go with a banks kit but I skipped that step incase I wanted to go back, which I did.
406angler
Jul 23, 2017 04:21 PM
enrand
Apr 1, 2017 06:14 PM
rowdie-stang
1997 - 2003 F150
Feb 17, 2006 10:34 PM
72ford360
Oct 22, 2004 11:32 AM
