460 ignition timing questions.
I don't mess much with the guts of a Ford distributor, it's a pain to tear it apart and try to tune it at home. If you had the money, you could go aftermarket with the ignition system. You could go with a MSD system that is triggered by the Ford dist, some of them do have a spark retard. You could try a HEI retro fit. I am assuming they are just like the original GM HEI, the springs and weights are up on top where you can get to them easily. And MSD and others sell distributors also, but it's not cheap.
You might want to find another stock used duraspark II and just drop it in place and see what it does just as a baseline setup compared to your modified one you are running now. Once you strip the original setup off the engine, you are on your own as far as setting up the tuning.
P.S. I have messed with the GM distributors trying to set them up. I will warn you, if you use very weak springs to bring the timing in early, that sometimes they are too weak to reliably bring the weights back to there stops. So the timing can "hang" a little bit advanced randomly, giving you cranking problems once in awhile.
Im going to run it at 14 for a while, and if it hot starts, back to 12.
as for the ds2 unit, this is a remanned unit, I wouldn’t feel comfortable tearing into them more than just verifying it’s retarding the start.
it just bothers me now a little bit that it is retarding the ignition 10 degrees and still struggles. The guy tells me that sold me the cam, lifters, spring, recurved the dizzy, that he hasn’t seen any issues in all his years building bbf like this one, engines struggling with 14-16 degrees WITHOUT spark retarding feature...
I want to check thermostat and the cooling system, to make sure it’s not running overly hot (dummy light) and I also want to check static cylinder pressure during crank. I guess I also need to verify tdc on the crank balancer.
I’m not even going down the road of an up to snuff starting system....
the problem basically disappeared once I retarded initial timing, so I’m either in the “slipped damper” and timing “isn’t as shown” or the cam is too advanced mechanically.
I guess I’m just perplexed why “it should crank as free as an engine with no plugs in it, even without the starting retard feature, from 14-16 degrees initial timing.” Here I am had to drop to 10 to get it to do the same thing. I’ve moved beyond the starting, charging system, and I’m looking mechanical...
However, by dropping that timing I got reliable starting, which I tend to prefer over the power most of the time. I can start creeping up timing to find that sweet spot, but wanted to make sure I didn’t have issues elsewhere. Hence the white wire testing.
Easy answer is as such, get the distributor re-curved again to bring in timing quicker, while still maintaining the initial 10 degrees during start.
When you are seeing that 3v on white, is the R/LB still showing a full 12v?
I am not following what you are saying here, particularly the part in quotes: I guess I’m just perplexed why “it should crank as free as an engine with no plugs in it, even without the starting retard feature, from 14-16 degrees initial timing.” Here I am had to drop to 10 to get it to do the same thing. I’ve moved beyond the starting, charging system, and I’m looking mechanical...
What is the basis for it cranking at 14-16 like it has no plugs and without the dsII retard feature?
Adding the details of my setup just for reference if it helps. Disregard if not.
9.5:1 cr
Recurved dizzy from Scotty. Total is at 3000 rpm
Initial was recommended to be 14-15 but I believe I am at 13 right now (will check again once I get a few more miles on the engine)
Performer intake
600 cfm quickfuel carb
XS Torque Powermaster starter
Hedman HD (old thicker ones) coated headers
Whether hot or cold it spins over like nothing.
Before the rebuild when completely stock (smog and all) it was really slow hard starting. Same battery.
9.5:1 cr
Performer intake
funny you attach your build, mine is basically identical, and I’m in contact with Scotty, he did all the recurve, cam etc. The quotations are basically what he said to me, it should have no issues cranking that motor at 16degrees. I’m only at 9:1 compression, same starter etc.... and you say you have no problem. Here I am with 14 degrees and so far no problems, but 16 degrees acted like starting a bulldozer after sitting for 10 years...
if 14 degrees works good after I get some miles on it, I’ll be fine, but I know I had to bump it to 10 to get rid of that sluggish start. I went from 16-10, and am now trying to creep back up.
I originally had a new Mastertorque on it and it was exhibiting really bad hard start issues. The first dozen times it started great. Had O'Reilly's test it in the truck and it tested bad. Swapped it for the XS and night and day difference.
I would give that test a shot. Might be as simple as a bad unit. I wouldn't have imagined mine was bad almost out the gate either.
