No Spark
Old Aug 23, 2020 | 10:42 PM
lexpression's Avatar
lexpression
No Spark
1977 F150 460. I'm a rookie and I'm baffled. I got everything working fine, but decided to tighten up the alternator cable. Then crazily now I have no spark. I can't imagine they are connected. I replaced the coil, distributor cap, rotator, and plugs. I have voltage (12 volts) at the coil connectors but I'm not sure how to check voltage coming out of the coil or how to make sure it is working through the distributor. There is no spark at the plugs. Anyone have some ideas that I can start to track down my problem.
Old Aug 23, 2020 | 11:23 PM
440 sixpack's Avatar
440 sixpack
Probably your control module. you should always carry a spare anyway so if that's not it you didn't waste any money.
Old Aug 23, 2020 | 11:48 PM
markdeimling's Avatar
markdeimling
Here is a site to trouble shoot the duraspark, that's what it sounds like is bad with yours.
https://itstillruns.com/troubleshoot...-12174178.html
Old Aug 24, 2020 | 11:23 AM
meangreen92's Avatar
meangreen92
Did you tighten the connection at the alternator, or at the starter relay/solenoid?
Old Aug 24, 2020 | 11:30 AM
440 sixpack
He says he has 12v at the coil so that rules out many possibilities.
Old Aug 24, 2020 | 11:43 AM
lexpression
Yeah, I was thinking that because I'm getting voltage at the coil then the inline fuse at the alternator is probably not the problem. Thanks to your guys advice, I went back to the controller and as I was checking it over both of the plugs that connect to it disintegrated in my hands. To try a test, I clipped off the starter wire plugs and re linked them together. Now when I start it, it won't stop turning over unless I unplug. The voltage continues to go to the wires while it is turning over, but not when I unplug. Because I don't know that that means, I'm going to go and buy a controller, and clean up both of the plug connections and see what happens.
Old Sep 12, 2020 | 10:30 PM
lexpression
Update. It was the control module. Unfortunately, because the plugs fell apart I needed to rebuild them. In the process I put the two wire plug together backward. This caused the car to get spark would would only stay "running' if the key was turned all the way to the start position. It was an easy fix, but I thought I'd circle back just in case someone else has the same issue in the future.
Old Sep 13, 2020 | 05:31 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Thanks for the circle back around, nice to know how one problem will cause another and how to fit it.
jb50F1
26
Jul 5, 2010 07:37 PM
rgutierrez
Apr 28, 2010 08:18 PM
82-4D-F250
Apr 26, 2009 10:38 PM
48' fordster
Flathead V8 & Flathead 6
15
Apr 23, 2007 06:33 AM
WickedPete
Aug 4, 2004 08:31 AM
