Quick question, I'm wiring my truck right now as 12 volt Neg earth, and I'm unsure about something regarding the ignition switch.
Got a repro one from DennisCarpenter, and it's rather unhelpfully labeled. It has three terminals, labeled "Coil" "Rad GA" "Am" and i'm unsure which of the latter two is battery/hot, and which is the accessories terminal, if there even is one. I'm also wondering if it has the usual off/accessories/ignition positions. It has three positions but with stuff this old you can never assume anything.
I want to say "Rad" stands for "Radio" and is therefore is the accessories terminal as the original doesn't appear to have that mark, only "GA". But I can't be sure.
I have the seized original with cut off pigtails, but all of the wires are yellow, which makes the wiring diagram useless. I would test it with my multimeter, but it went and died and i've yet to replace it.
The RAD post gets wired to the gauges metal connecting strap, AM gets wired to 30A circuit braker next to the instrument cluster & Ing. to the coil.
So on a 12 volt negative earth setup, am i correct in presuming AM would be our power hot lead, and RAD would be the equivilant of the accessories lead?
Thanks.
Don't know if this helps, but here's my notes on how I wired mine. The diagram had Coil, BAT, GA, but my switch had IGN (Yellow), BAT(Red Green), STA(Black Green). So, GA = STA on mine. Can't recall what that was actually, nor what GA or STA mean. Mine is also 6 volt... with a positive ground. So, this may be useless.
Anyway, I came across this thread because my battery dies every once in a while randomly and I think there are 3 positions for the key and I randomly might be leaving it on the wrong one and draining the battery when I turn it off. Not sure what's pulling power even when I do that though, no lights are on.
